Results 1 to 10 of 10
07-29-2010, 04:34 PM #1
- Oct 2009
- Eastern Washington
- 48
Dealer trying to determine if our 4 yr old Compressor is out
What is the test ('annie' ?) needed to determine if the compressor on our Carrier 3 ton needs replacing:
* Heat of day it shuts off.
* Starts back up after awhile.
* Misting water on the outside unit speeds up the cool-down
Or.. is there a thermo switch that causes this compres. to shut off. Dealer guessing it's the compressor(warrantied for part)
It work fine early evening and thru the nite
Doug
07-29-2010, 04:48 PM #2
Your HVAC company should be able to determine the cause of the problem. There could be more than one issue that creates the same syptom but it takes depth of experience to ferret out the cause.
07-29-2010, 04:52 PM #3
- Oct 2009
- 48
07-29-2010, 04:55 PM #4
Losing confidence?
You should be!
07-29-2010, 05:00 PM #5
Yes, there is a switch that turns the compressor off if it gets too hot. If your HVAC company can't solve the problem, you'll have to get someone in who knows what's going on and if it's a new warranty thing, back charge (or try to) the original company. The next time (if there is one) shop more carefully.
07-29-2010, 05:19 PM #6
- Oct 2009
- 48
07-29-2010, 05:27 PM #7
- Mar 2005
- Houston, Texas
- 11,646
1/4 to 5/8? That's quite a jump. Maybe 1/4 to 5/16?
07-29-2010, 05:51 PM #8
- Oct 2009
- 48
07-29-2010, 05:55 PM #9
Don't blame you for losing confidence. They're guessing, clearly. Call another, hope you can get the original company to cover the costs but if not, that's the tuition for the experience you've gained.
07-29-2010, 06:11 PM #10
- Mar 2005
- Houston, Texas
- 11,646
