Results 1 to 2 of 2
    Jan 2010
    In a Pineapple Under the Sea
    Cooking Grate Care
    I have a Weber Spirit with porcelin coated cast iron grates. Besides brushing them with a grill brush after every use or letting the food build up burn off every once in a while is there anything else that needs to be done to them?
    N.E. Iowa
    I see you've had no replies yet so I'll give you my
    I personally have never used porcelain coated grates, mine are 1/4" dia. stainless steel. This is how I keep mine from building up too much cooked on food and sauce. I get the grill nice and hot and then apply olive oil using a napkin held with tongs. Occasionally taking a wire brush to it get's the underside cleaned off.
    I don't know if it's the answer for your porcelain grates, and maybe someone with more experience will chime in.
    Happy cookin'!
    ______________________________________________
    Sign petition to limit Congressional and Senatorial terms. http://www.termlimits.org/
    "We may have all come on different ships, but we're in the same boat now."--Martin Luther King Jr.
