Analysts Inc?
Originally Posted by
LiBrman
Do not mix the two. Chromate inhibited and Molybdate inhibited operate at two entirely different alkalinities. You probably could get away with adding a little of the molybate LiBr to the other but if in the process the alkalinity goes too high you will have problems. My worst nightmare with LiBr was being mistakenly told ( by a professional lab ) to raise the alkalinity of chromated solution. I did so and the yellow solution turned pink, then purple and it became a couple of seasons of filtering a purple paste out of the solution. Eventually I found I was given wrong advice and the entire problem was because the alkalinity was too high for chromate. I lowered the alkalinity and the problem went away. You might find that after lowering the alkalinity of the molybdate libr it can be mixed and for that advice I would check with Rocky Research.
I use Rocky Research out of Boulder NV for LiBr testing and they sell lithium chromate. Contact them for how to buy, but I believe after they test your sample they can sell the recommended amount. I have worked with their Michael Coronel and have been completely satisfied with their service over the past 7-8 years. Check out their website rockyresearch.com , click on services > analytical services > commercial. They used to offer more info on the site so I would just call them and go from there. Also Rocky Research is not the professional lab I refered to above.
To much work with too little time!!!!
