Results 14 to 26 of 52
    Great post in an open forum....I can see it now...
    What kinda FreeZone ya got wit ya???
    R what? Aw, shoot, it don't make no differnce, they's all the same!!!
    Go ahead and charge that bad boy right up!!!
    Them thar Profeshunals on that there googly moogly forum say theys' does it all-a-time.
    Git-R-Done!!!!
    Jul 2002
    Slacking off right now
    I was out of town 5 hr drive to go get 12 - I should have had enough but I didn't - farmers dog tucker cooler ( or freezer ) I don't remember - repaired leak woulda caught hell if I had to go get 12 - I finished it off with 502 a bout a 1lb of 502 to 12 lbs 12
    never heard a thing ( I figured 502 was partly 12 anyways )
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    Jan 2010
    Thumbs up
    Quote Originally Posted by 76olds View Post
    P.T. chart?
    P.T. chart. My thought exactly.
    Jul 2012
    I'm a little confused...if you put r-22 in a r-404a system, whether the capacity be 8 lbs (and you add 3lbs), 200 lbs (and you add 60 lbs), or 1000 lbs (and you add 100 lbs), wouldn't you have to adjust the txv's or anything? Since the boiling points, etc. of both refrigerants ARE slightly different?
    Quote Originally Posted by hankmoody View Post
    Let's do it this way.
    DON'T MIX GAS!
    Jul 2012
    DON'T MIX GAS!
    oh, i do it that way. i'm just confused how he's saying it'd work when they have different boiling points and such
    Oct 2011
    Chicagoland Area
    Why open yourself to potential problems?
    Out of all the dumb threads on this forum, this one is up there with the worst.
    RSES Certificate Member
    RSES-SWRA President
    Dec 2011
    bedford ind
    Can I use gasoline instead of mineral oil with r22?
    Jul 2012
    I would like to set up a guinea pig in my warehouse and try propane....Mayne run some blue rhino.through a couple filter driers and see what happens.
    Jul 2012
    North west Arkansas
    I hope I never run into a situation where mixing refrigerants is required. I recently started servicing cooler/freezers/AC, and only had to repair r22 AC so far, but the guy that did it before didn't seem real big on labeling, I've found notes written in marker with 239,r404/408 etc written on equipment, sometimes the same equipment...
    Jan 2010
    Quote Originally Posted by texasgentleman2 View Post
    I've found notes written in marker with 239 etc written on equipment, sometimes the same equipment...
    R239 that's a new one to me. Must be what you get when you mix
    Jul 2012
    North west Arkansas
    Oops, that was supposed to be mp39, thats what I get for typing before I got my whole pot of coffee down.
