Page 1 of 4 1234 LastLast
Results 1 to 13 of 52
    Reading, Pa.
    Mixing refrigerants? (let the flames begin)
    Ok guys and gals... I KNOW it ain't right or what's taught or what they say ain't comtatible (so they say) HOWEVER!
    I have come across units that have been marked by passed tech's "R-12/134A/409/hotshot.mix. And are working fine after I repaired a small leak and partially recharged with what I had on hand (134a).
    I've also used R22 instead of 404a to get a WI freezer running after fixing a leak, havn't had to go back in 6 months and used 3lbs on a 8lb system.
    The equipment,refrigerant,oil and other manufacturers adamantly proclaim that they WON'T mix but they will.
    Now before you get your panties in a bunch! I don't do this all the time as a general practice, but only in a pinch. If the system pulls down to temp. then I leave it at that.
    you can get as technical as you want but, R12,134a,409,hotshot,and a few others ALL have REALY close head pressure.. and the bottom line is protecting the compressor. R 502,404a,r22...ect are the same.
    NO they are not intercomtatible with P.O.E. oil and Mineral oil. I know this but if it's a mix then as long as the majority is oil compatible it will work. Reduce performance and life???? maybe.
    My proof I recently came across a 1 door upright freezer that was to be scrapped,marked 404a, The comp. worked so I fixed the evap. leaks and weighed in the 16 oz charge of as equal parts I could of 134a,404a,22,409a.
    and also some recovered witches brew
    Well it reached -10 F in 45 min. from 80 F.
    Hmm?
    Now let the beatings begin. (no I didn't make this up to provoke you guys...)
    We the willing, led by the unknowing, for the ungratefull, have done so much for so long with so little, we are now qualified to do anything with nothing.
    Refrigeration is all the same weather your making Ice, refrigerating or freezing the product.
    Arizona
    this should be good. LOL
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Reading, Pa.
    The 1 door upright at the end of the post is my guiene pig (spelling?)
    (not a customers! In my driveway enjoying the 90+ F weather.
    Jan 2010
    Talking
    I love your thinking outside the box. You know this is really going to upset some people right ? Maybe you could come up with your own flavor oh that's right you already have. I do know of a W/I cooler that was R409 and switched to R134a with no oil change. Dang thing has been running like a Swiss watch for the past 5 years.
    Chicago, IL
    Quote Originally Posted by Executioner View Post
    502 and 404a will get along fine as long as you have enough 502 to transport the oil. 22 doesn't belong there. at least not too much of it. runs high head pressure, compression ratio, and discharge temps in low temp applications. Its a quick way to a cooked compressor on a system not designed for it.
    I know a lot of guys who will mix the R-12 variant refrigerants (401a, hotshot, etc) and claim no problems with operation.
    I have never knowingly mixed refrigerants and never will.
    When working on larger equipment (1000+ pound charges) throwing in 200# of R-22 in an R-404a rack may work, but it may also have consequences that I don't want to consider, such as me losing my job when my company has to pay for the recovery, replacement and disposal of a half ton of junk gas that I created.
    Oct 2008
    Winnipeg, Manitoba, Canada
    i've topped off a 404 WIF with 22 once in a pinch, but i only did cause i was working in a fly in only location and didn't have time to wait for 404. this was over six months ago and the unit is still working great.
    Jan 2010
    If you do decide to mix refrigerants there is one tool you will not need. Do you know which one ?
    New Mexico
    Propane is a good emergency substitute for R12. Just don't have a leak.
    I know if you substitute the old 70's R500 with R22 it will cost you.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Chicago, IL
    Quote Originally Posted by hvacker View Post
    I have a customer (church) that had an r-500 system that i topped up every year with 5 lbs r-22. worked great. Untill the compressor fell out and ripped off the suction line. Then they got a new r-22 condenser and TXV
    New Mexico
    Quote Originally Posted by craig1 View Post
    A shop in Illinois serviced a, I think, 10 ton Carrier heat pump. After three compressor failures someone read the data plate. It was a R500 machine that was serviced with R22. Some were sworn to secrecy.
    There are large operating pressure differences between the two. R-12 is a lot closer to R500 than R22.
    My guess is the compressor stroke is different as the cfm should be different for the two.
    SMW Lu49
    P.T. chart? As far as R500 goes, it is really close to R12 but the head pressure is higher(I think, it's been a rough 2 months, at least i think it's been 2 months, I'm really burnt out right now). Couldn't you pull out the 500, and recharge with R409a and it would be fine. We actually have R500, so if I had something that old, I could put the right juice in it.(The R500 is buried along with the R11).
    Jan 2010
    Oklahoma City
    I have always wondered about that. Boss wanted me to carry hotshot but not 134 so I was alway recovering the charge and recharging with hotshot. I finally started carrying 134. Life is now easier.
