Results 1 to 13 of 15
    Question
    I changed the evaporator and I used my electronic leak detector to make shore that the new one was not leaking. But what is a good why to check the condensor for leak because there are a lot of trees by the unit and my detector go off some time out in the open. I am going to go back by the house tomorrow to recheck the evaporator. the unit was going down in two to three days.
    Indiana
    Get a couple cheap plastic tarps and wrap the condenser. Then go in from the top with the sniffer.
    Check your coil for oily or dirty spots. I have never seen a leaky Trane condenser coil, but chrck the copper lines in the unit. I've had several that the copper has rubbed and caused leaks. This seems to be an ongoing problem around here.
    Maryland's Eastern Shore
    Evacuate the system and take it 250 psig with nitrogen and let it sit... most effective leak detector I've found... If it holds, no worry, if it drops than wrap the condensor and go at it...
    And never be afraid to break out BIG BLUE.
    Florida
    I agree with wrapping the condenser....but why go in from the top? Freon's heavier than air and will sit down the bottom.
    Florida's space coast
    I found a leak in a two year old Trane condenser coil just last week.
    It was in the bottom circuit at the copper to aluminum junction which was wrapped with cork tape.
    Tek Mate leak detecter got me in the neighborhood and after peeling back the cork tape Big Blue did the rest.
    Waiting on the warranty coil to be delivered to the shop.
    We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
    Nov 2003
    South Carolina
    Pressurize it...wrap it...sniff it..then big blue it..works every time.
    Jan 2005
    Central Fl
    I have found a couple of these recently myself. We've had a few at my shop. 410A systems. It's always (so far at least) on the bottom circuit in the aluminum a few inches past the transition from copper. I have been hoping it won't be an epidemic, but I'm not feeling too good after hearing others are finding the same thing. We install ~200/month.
    Senior Tech Guest
    200 per month?!?! Must work for McDonalds HVAC...over 150 Billion sold...
    Jan 2005
    Central Fl
    We are a fairly large company (130 employees) that does a LOT of new construction for retirement communities in central Florida. The main community is around 50,000 and half grown. It is basically it's own city. They have their own TV station, radio station, newspaper, and bank, just to name a few. They have a sorry website, it is http://www.thevillages.com .
    I have only ever found 3 or so of them leaking. Trane makes a repair kit that works real well. You still have to recover the refrigerant, but it saves you from having to totally strip the unit down for a coil changeout.
    If you get the repair kit, follow the instructions exactly and you won't have any problems. Try to do it without reading the instructions and you will regret it.
    RSES Certificate Member
    RSES-SWRA President
    I'm not very far from you.
    Work mostly from Viera/Suntree in Brevard down to Indian river county line and beaches from Patrick AFB to Sebastian inlet.
    Jan 2005
    Central Fl
    I have used the repair kit on R-22 systems with sucess. The 410A coils that I have found leaking recently have all been around 12-18 months old. We have been replacing the coil rather than repairing it considering its age.
    I'm not too sure what I think about the repair kit on the high side of a 410A system. Mark, have you used the repair kit on 410A and had enough time pass to feel confident it will hold up?
