    Nov 2003
    I installed a new 5 ton condenser unit at a daycare center. Pressure test fine, vaccume held 24hrs. Opened king valves then started the unit. Compressor sounds like a jack hammer and my guages do not show a change in pressure. Any help? This is a 3 phase unit and the compressor was pulling 11 amps when i pulled the power.
    scroll running backwards. reverse 2 leads of the incoming power.
    Washington,NJ
    Sounds like you need to change the electrical input phasing to the unit.
    Sep 2001
    East Stroudsburg, PA
    Yeah. This is true.
    It's in the I&O manual, kid.
    Oct 2001
    next time bump the condenser fan if 3 phase for top discharge of the air,or push the compressor contactor in next time for 10 seconds and grab the suction if you feel the slightest heat reverse the 2 leads.
