Results 1 to 9 of 9
    Kaufman county, Texas
    f150 overheating. Fan clutch?
    Only starts getting hot when in idle-parked/light or drive thru. Does okay when on the highway.
    Fan can spin a quarter turn or more if you reach in and give it a whirl, same whether the engine is hot or cold. No grinding or anything like that.
    All else I can think of is the thermostat or air blockage. Not the latter from looking, and the former seems unlikely based on my GM experiences.
    triton v8, 97 model. Any ideas to save me a road-side repair day?
    I draw all my schematics in crayon now. If they cannot always be correct, they can at least be colorful.
    Service calls submitted after 3PM will be posted the next business day.
    I give free estimates [Wild Ass Guesses] over the phone.
    I am not in business to make money from other people so that I can afford to work for you for free.
    If the fall is over, mmmm let's say, 6 feet or so,.. I do not 'bounce' very well.
    chicago suburbs
    when's the last time you replaced the anti-freeze?
    FILL OUT YOUR PROFILE!!
    Tampa, Florida
    sounds like...
    sounds like 1 of 2 things: first one being the system is low on coolant. second - fan clutch slipping too much. when you rev the engine up, do you feel lots of air being pulled through the radiator by the fan?
    Quote Originally Posted by badbillr View Post
    Thanks tinner and badbill! I went out and checked the Afreeze and the reservoir is dry as a bone. No radiator cap, just the reservoir thing.
    Me and my head gaskets thank you very much!
    Quote Originally Posted by tinner73 View Post
    Over 6 years... Sealed system I figure. I did not even check the reservoir level or anything. This problem seemed to just pop-up all of a sudden, I don;t think it was running hot before this. I have dial gauges on the dash, not just lights.
    chicago suburbs
    test/change your anti-freeze..do you have a tester? it doesn't last forever
    Oct 2009
    Airflow problem, check between the condensor and radiator Chaff and crud can accumulate between them and restrict flow. Spin the fan on a another truck and compare the drag.
    chicago suburbs
    get one of these..you're welcome.
    Good advice, taken and thanks guys.
