Results 1 to 13 of 33
07-09-2010, 01:05 PM #1
- Jul 2010
- 12
20X8 supply equivalent to 26X6 supply? Heatloss guys says
I cannot go 26X6 because the ratio is over 3 to 1... another heat loss guy says it's okay... can't find any answers on the internet... please help.
Thanks.
07-09-2010, 01:19 PM #2
Regular Memeber
- Jul 2010
- Andalucia
- 3,210
Short answere is yes
07-09-2010, 01:26 PM #3
- Feb 2010
- The midwest.
- 663
07-09-2010, 01:34 PM #4
Regular Memeber
- Jul 2010
- Andalucia
- 3,210
I read it as he wanted 26x6 but couldn't do that because of "ratio" for some reason and they were going to use 20x8 which would be slightly more cfm
07-09-2010, 01:40 PM #5
- Jul 2010
- 12
my bad... here is the complete scenario
I currently have a 20X8 supply air (2.5 to 1 ratio) and the equivalent cfm wise is indeed 30X6 but one heatloss guy says the ratios are over 3 to 1 on the 30X6 (5 to 1 ratio) and as such it is not a good idea from a design/flow perspective regardless of the cfm equivalence... the other heatloss guys says it's a bungalow so we can get away with it... confused as to why this ratio is an issue and I could really use the headroom in the basement but would never comprimise the performance of the duct work...
thanks.
07-09-2010, 01:43 PM #6
- Jul 2010
- 12
again, I'm really confuses as to why these ratios
are important... I thought if the CFM is maintained there would be no problem... please clarify.
Thanks.
07-09-2010, 02:15 PM #7
- Jul 2010
- 12
CFM vs Duct Ratio's
I currently have a 20X8 supply air (2.5 to 1 ratio) and the equivalent cfm wise is 30X6 but one heatloss guy says the ratios are over 3 to 1 on the 30X6 (5 to 1 ratio) and as such it is not a good idea from a design/flow perspective regardless of the cfm equivalence... the other heatloss guys says it's a bungalow so we can get away with it... confused as to why this ratio is an issue and I could really use the headroom in the basement but would never comprimise the performance of the duct work...
Again, I'm really confuses as to why these ratios are important... I thought if the CFM is maintained there would be no problem... please clarify.
Can I go 30X6 or must I stay with 20X8?
Thanks Again.
07-09-2010, 03:10 PM #8
- Feb 2010
- The midwest.
- 663
07-09-2010, 03:50 PM #9
- Jul 2010
- 12
there must be a reason for this ratio rule...>>>
I agree with you that the 30X6 will do cfm wise but what are the pitfalls/cons of breaking the 3 to 1 ratio rule and if it's not a big deal why have the rule in the first place? There must be a reason for it... perhaps the air does not move as easily/efficiently or the ducts are noisy?
Any other input would be greatly appreciated...
Thanks!
07-09-2010, 05:07 PM #10
Rules of thumb serve two pruposes.
1. The are useful as a quick double check in situations.
2. They are necessary for techs with little knowledge of the scientific fundamentals or little skill in applying such knowledge. They are better than a wild guess."I have never let my schooling interfere with my education."
Mark Twain
More at: http://www.quotationspage.com/subjects/education/
07-09-2010, 05:09 PM #11
- Jul 2010
- 12
thanks lynn... so would you go 30X6 to replace 20X8 in...>>>
your house and ignore the rule if you needed the headroom or would you stick with the 20X8.
Thanks again.
07-09-2010, 05:15 PM #12
- Jul 2010
- 12
yes or no - can I replace a 20X8 duct with 30X6...>>>
with regards to cfm and the less than 3 to 1 ratio rule?
Would you do it in your house, why or why not, pros and cons for both?
Last post on this subject... just can't get a straight answer.
Thanks again for all or you help!
07-09-2010, 05:55 PM #13
- Feb 2010
- The midwest.
- 663
