    Have an older Train Ac unit Roof mounted Compressor /exchanger unit . The fan and compressor cycle on and off every 3-5 secconds. The unit is not getting cold. Any Ideas? I have done no testing yet, just observed
    Clayton,NC
    Sounds like it's shutting off on either low pressure or high pressure. Get a tech out there to put some gauges on it.
    Question check the low voltage electrical wiring...
    there may be a loose connection at the thermostat or other related components. Just a suggestion.
    villalba,p,r
    if you don't undestand,plase watch you self.
