Results 1 to 8 of 8
Thread: trane chiller ?
    Jul 2002
    hamilton ont can
    CVHF128KA1
    this is a 123 machine. economizer to compressor line cracked at weld at top of economizer. has anyone else had this problem? just checking to see if this is an isolated problem or does trane have a problem with these? no hurry and thanks in advance.
    When was the unit built?
    in a tree looking in your window
    I have been with factory Trane for about 13-14 years now and have only seen 2 leaking welds, 1 on a big 1200 ton heat recovery centrifugal and 1 on a RTAC. Usually when leak testing, welds are the last place I look, 99.9% of the time it is some flange leaking, I would say your leaking weld was an isolated problem.
    If you dont stand behind our troops, please feel free...........to stand in front of them.
    Jul 2002
    hamilton ont can
    [img]http://ww2.imagewiz.net/images/hvac/117182_007f.jpg
    [img]http://ww2.imagewiz.net/images/hvac/117181_006f.jpg
    [img]http://ww2.imagewiz.net/images/hvac/117180_005f.jpg
    here are some pics i hope
    Sky '99 to '00
    this is a 1300 ton 2 wheeler
    Dec 2003
    Half way between North pole and Equator
    There was a mandatory retrofit a few years back that required a metal ring/plate to be welded around that spot, and also brackets welded onto both ends of the econo and cond. Then bolted together, to help stop vibration. Has this been done?
    It looks like the weld has been cold rolled.
    Jul 2002
    hamilton ont can
    try again
    Jul 2002
    hamilton ont can
    drivewiz: yes for support brackets at each end of econ. as for ring plate this is as found in pics. this unit has 2 brothers in same room and iam thinking the same problem likely exists with them. likely going to check them anyway. depends on what customer wants. thanks for info
