Results 1 to 11 of 11
    Jul 2002
    NorthEast
    15 Ton Trane voyager - 2 compressors 7 1/2 Ton each
    8 cube drier on each 3/8 inch liquid line ,installed by others
    After intense condenser cleanings the head pressure will run at 344 P,S,I, with 65 P.S.I. suction
    We were lead to believe that if a liquid line drier is badly restricted you will see moisture on the drier
    Can the driers be adding to the high head pressures
    Will larger driers help
    Thank You
    Apr 2001
    did you "split " the condensor to clean?
    Don't interrupt me while i'm talking to myself
    Wichita Ks
    i have had driers with as much as 150lbs pressure drop with out a noticeable temperature drop across it. the only way you will see moisture on it if it is below dew point. first thing would be did you split the coils like gerryboy said? if so and you suspect the drier then go with a bigger one. we had a voyager this summer that a drier plugged up on it and the system was never opened up or had a leak. we did go with a larger drier. also make sure all the orfices are feeding.
    As stated above you can have large pressure drop and no sweating. Check for pressure drop and temperature drop, neither should be more than 3, 3# or 3f. In my opinion a 8cu in drier is way to small for that system. It may be ok from the factory but any time it is replaced it should be larger.
    If all else fails....Try reading the directions!
    Tell it like it is and let the chips fall where they may.
    Any views or opinions stated here are strictly my own.
    villalba,p,r
    that system has stagefans control,you better check if the system,is working step by step.
    Apr 2003
    Greenback, Tennessee
    The short answer to that question is no, BUT if the LL dryer is restricted someone may have over charged the system to get the back pressure up. Is there more then a 5 degree temp drop on the LL from the condenser outlet to the metering device inlet? If so then you have a LL restriction. .
    -Marty
    dont think it would be a LL drier causing problem / check cond, fan working properly./ poss restriction at txv or bad powerhead and some overcharged to prevnt icing good luck
    Isn't an 8ci drier a little on the small side for 7.5 tons?
    Oct 2002
    Whats an 8 cube?
    Jul 2002
    NorthEast
    We were hoping for a two peice layered condenser coil.
    This is a one piece coil.
    We did drop the head pressure, on both circuits. from 400 P.S.I. after a good cleaning
    It appears that both compressors were changed a few years back.
    There should be at least a 16 cubic inch drier on each line.
    Trane has hinted that also relocating the driers into the evap
    section
    closer to the metering device will also help.
    Thank you
    Unless you have hot gas on the systems I would expect to see low suction if the dryer is restricted.
    If you don't have the time to do it right the first time, when will you have the time to do it over?
