Results 14 to 26 of 34
    NW Arkansas
    Quote Originally Posted by midhvac View Post
    Those Yellow Jacket hoses with the ball valves permanently attached are pretty pricey. Has anyone had luck with the Yellow Jacket ball valves that just attach to your existing hoses?
    Yes
    Signature on hold. Trying to find a real Jefferson quote I like. Others here have bogus Jefferson quotes too.
    Aug 2009
    Beatrice, NE
    I always keep the suction pressure from the last sytem I worked on in my hoses and manifold; I drain the high side back into the system through the low side so whatever that pressure is stays in the gauges.
    As far as bleding the 6" extension, I use valve core depressors a lot of the time, so when I attach the hose to the depressor I can bled some of the pressure from the gauges at the depressor. This also saves freon burns in those tight places.
    Oct 2008
    Pittsburgh, PA
    I don't have half the experience of many of you, but I actually use NRP low loss fittings and YJ ball valves. I trust the ball valves a lot more. I read somewhere that someone didn't recommend leaving your manifold full of gas. It slowly stresses out the hoses or something.
    the ball valves you put at the end are greattt
    like someone said earlier
    you can, purge/bleed right to that point!!
    very nice
    I have an assortment of ball valves, low-loss fittings, adapters, etc. and it seems like the yellow jacket ball valves are the ones I consistently go for.
    rob
    i almost did not recognize your avatar??
    ddc controller because the display is not on it!!!
    when you install one do not forget to calibrate it!!!!
    what happened to your seasons 4 unit avatar??
    Quote Originally Posted by BergerMech Rob View Post
    It's a Mcquay Microtech 200 controller - they don't need calibration!!!!
    I thought you were mad at me because I work for the big non-union meatball now!!!
    lol
    its okay that you are a meatball now!!!!!!!!!!!!!!!!!!!!!!!
    never mad at u
    i thought that was off of a mammoth ??????????????
    looks exactly the same???????
    ribbon cables and fuses in the exact same place
    lol
    it is the exact same controller!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
    in the first menu after password, mode-occupied/unoccupied/remote start
    next item calibration
    but ofcourse that was for a varicone vane controller..
    i would live on the edge and guess there is NO varicone vane for duct static control?? LOL
    but it is the exact same board
    i have 4 of them in my truck
    just grabbed one and compared it to your avatar
    how is work????????????????????
    Midwest
    What about blow-back from the ones with the ball valves vs. the low loss ones - like when you're unscrewing the hi side hose from the Shrader?
    Quote Originally Posted by supertek65 View Post
    Work is cool - Making more money than I ever have, I haven't put in any OT that I didn't ask for, I'm learning something new every day, and I'm enjoying being a little fish in a big pond.
    There's some chiller porn in the "office pictures" thread that I posted.
    Never really been much of a problem for me. Sure, it's a tiny bit more than the "psst" you get from a low-loss, but the fittings are so much more reliable and useful.
    chiller porn!!!!!!!!!!
    I'm there!!!!!!!!!!!!!!!!!
