Results 1 to 4 of 4
    Jan 2001
    sliding glass doors
    Got a sliding glass door. For the last couple of years it has had days where it is almost impossible to open then all the sudden it seems to work fine.
    Now Ive noticed that the front bottom edge that closes against the frame is eating into the bottom tray...chewing up metal.
    ANybody know if there are replaceable parts on the bottom of the door... wheels or rollers or something....and how exactly do you get the door out and back in.
    Yes..I can probably google it....but Id rather ask here where I can possibly ask follow up questions if I get into a bind.
    The bible is my constitution and the constitution is my bible.
    WE THE PEOPLE refers to THEM and not YOU.
    Chewbacca Mom 2016
    Colorado flatland native
    I would buy a new french door. Sliders suck. Yup, all of um.
    Walter Matthau
    Grottoes VA
    I have to agree with spots, replace the door.
    To answer your question, yes you can get a track for the bottom and new bearing assy. They are pricey and you need to know the model number of the door.
    The doors come off easily, loosen the adjustment and then lift the door up and out from the bottom.
    Delaware
    To remove: depends on brand. Anderson has a trim piece that un screws, allowing you
    to pull the top out (towards you) then lift up off the track. Some doors have a leveling
    adjustment that raises or lowers the wheel assembly. Inspect, clean, lubricate both
    wheels and track......if wheels need replacement try Lowe's. Liquid dish soap on track
    works well to keep it slide'n. Good luck.
