Results 1 to 10 of 10
    HVAC replacement estimate question
    Hello everyone,
    First off I am new and found this forum searching for model numbers.
    I had a company come out and evaluate my home for HVAC replacement.
    It is a 2 story home with 1686 square ft with about 600 square feet upstairs.
    This is the estimate I received and I have never had a unit replaced so I
    was wondering if this was a reasonable quote.
    I have other quotes from other dealers and I understand the equipment makes a huge difference in price but this quote seems ok with the equipment listed. Please let me know if I am way off. I live in the South East so A/C is more important than heat to me.
    Thanks...
    TRANE SEER 16/3 AFUE 95% /60 model #'s 4TXCB036, 4TTX6036, TUH2B060A9V3
    NEW FURNACE A/C AND COIL NEW OUTDOOR PAD AND DISCONNECT BOX
    FLUSH OUT LINESET AND CONVERT TO R410a INSTALL EZ TRAP IN DRAIN LINE
    NEW AUX DRAIN PAN AND CONDENSATE PUMP W/ SAFETY SWITCH. NEW FLUE TO CODE
    NEW EWC 2 ZONE SYSTEM TO SEPERATE UPSTAIRS AND DOWNSTAIRS ADD RETURN TO MASTER
    OPTION 95%VAR SPEED W/TRANE XL20i
    INCLUDES A 5 YEAR MAINTENANCE COOL CARE AGREEMENT
    Oct 2006
    uh oh someone didnt read the rules.....
    Quote Originally Posted by actuator View Post
    ??????????????????????????? I read them to what are you referring to?
    Oct 2006
    $$$$$$$ estimates $$$$$$
    Ok? This must be hidden in the rules as I didn't see it so please remove this post and have a nice day!
    Mar 2010
    Missouri
    Quote Originally Posted by tazman2010 View Post
    Hello everyone,
    I have other quotes from $XXXXX to $XXXXX and I understand the equipment makes a huge difference in price but this quote seems ok with the equipment listed. Please let me know if I am way off. I live in the South East so A/C is more important than heat to me.
    Thanks...
    OPTION 95%VAR SPEED W/TRANE XL20i $XXXXXXXX
    You are going to get Yelled at.. You CAN NOT POST PRICES HERE... It is not the equipment that makes the difference, its the person that installs it. You can take a million dollar system and put on a POS duct system and all you have is a million dollar POS...
    Hope this helps,
    Chad
    Quote Originally Posted by crego97 View Post
    Hope this helps,
    Chad
    Thanks and I removed prices..........
    Feb 2007
    Tazmzan, one of the moderators will X out the pricing, a lot of people make that mistake, and pricing varies for different regions so I won't comment on it. However, you are being converted from R22 to R410a refrigerant, I would recommend that the line set be replace with the rest of the equipment and not just flushed out.
    Some might question the sizing for that square footage. Be sure they sized up your house properly.
    If it doesn't go easy, you are not using a big enough hammer.
    Quote Originally Posted by HVACJOEK View Post
    Thanks, I was wondering about the line set as It is a 1985 system. I will ask to include the line set in the price so I get the correct size. The tonnage is online
    with 2 friends that have similar house set ups and square footage so I am ok with the ton they recommend.
    Feb 2007
    Glad to be of some help, have a cool summer.
