Results 1 to 13 of 13
08-17-2004, 05:16 PM #1
- Aug 2004
- NYC
- 2
I'm the guy to raised his hand.. volunteer to paint the
basement of a 36 unit condo ''basement''. My question is..
and I'm a stickler for safety.. There are, yes, you guessed it, 36 gas pipes (natural gas) leading from 36 gas meters in the middle of our basement elevator lobby. It's
my understanding that gas pipes should be painted black (they are presently painted the off-white, same as the ceiling) which they are running 2'' from,.. should I bring them back to black for safety sake. Are there codes that natural gas pipe should be black? I thought there would
be no mistaking them for water pipes if they were black.. I'm I going over-board..or What!!!! I don't think this is
a local code thing.. just common sense... or am I just plain toooo picky?
08-17-2004, 05:39 PM #2
Professional Member*
- May 2004
- Canada
- 316
I think it should be yellow
08-17-2004, 05:45 PM #3
Member
- Mar 2004
- 305
The nat. gas lines in our building are yellow.
08-17-2004, 06:03 PM #4
- Jun 2004
- Maryland's Eastern Shore
- 892
My understanding is the yellow gas pipe signifies a high-pressure line, "a line over 26" wc".... I've seen gas lines painted black, white, etc.... Probably would be best to check local codes...
08-17-2004, 06:26 PM #5
I would say yellow also.
08-17-2004, 06:27 PM #6
- Dec 2002
- 9,871
yellow
08-17-2004, 06:29 PM #7
- Jan 2002
- 1,895
Lable the pipes, see yellow and grey mostly
08-17-2004, 08:22 PM #8
Canadian code requires a yellow band every 6 ft or bend or tee etc other wise paint them any colour you like.
It may be similar in your neck of the woodswww.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
Gonads serve a useful purpose but are no substitute for brains
08-17-2004, 10:33 PM #9
Yellow, or a stencil/sticker every 25' or in each room along length of pipe.
In the Navy all the pipes are color coded. White = steam, yellow = fuel oil, purple = jet fuel, green = sea water, a whole rainbow in the boiler room!Col 3:23
08-18-2004, 09:11 AM #10
- Aug 2004
- NYC
- 2
thanks to everyone for your color suggestions. i
think I'll do it the same color as the ceiling
and tag/mark them gas ever 6 feet or so. love this
website...
08-18-2004, 11:43 AM #11
- Jan 2004
- Connecticut
- 170
Gas Piping Identification
According to the 2003 International Fuel Gas Code (section 401.5 Identification)
"For other than Black Steel Pipe exposed piping shall be identified by a yellow label marked "Gas" in black letters. The marking shall be spaced at intervals not exceeding 5 feet. The marking shall not be required on pipe located in the same room as the equipment served."
08-18-2004, 12:37 PM #12
You really volunteered to Paint?
Still learning opinions welcome.
08-18-2004, 02:01 PM #13
What if they wanted you to wallpaper? Yellowmeans gas in my book.
Walter Matthau
