Results 1 to 13 of 33
    Jul 2010
    connecticut
    Confused trouble with split system. low suction.
    Got a trane split system that's about 10 years old that I was sent to change the compressor on just because the town maint. Guy wanted to. Changed it then charged system and problems popped up. First of all the condenser is oversized. 5 ton and ahu is 3.5 ton. Wtf. Suction pressure is low 43 psig.70 ambient temp. 200 psig liquid press. Have 22 superheat at evap and 19 subcooling.28 delta tee across evap. Kindahigh airflow. What will happen with an oversized condenser ? Please help. Txv system
    Colorado flatland native
    you contractor kemosabe?
    Walter Matthau
    Tn.
    I dont know
    Tn.
    Quote Originally Posted by m-cooling View Post
    I dont know
    But I would guess you have voided any warranty you had
    Jul 2010
    connecticut
    Yes I'm a contractor. Warranty is out the window. Just curious of symptoms associated with this.
    If you're a contractor, why knowingly do something that's wrong?
    A job like this, you should have walked away from. Or, made them do it right.
    Hope you got paid in advance.
    Jul 2010
    connecticut
    Frown
    Quote Originally Posted by the dangling wrangler View Post
    Why r u jumping on me if u don't know the story. All I want is answer to question.not u questioning the job. If u need to know I was sent to the job to replace the compressor somebody else shot down a year ago. I replaced it like I was told then while running it I found problem.
    Quote Originally Posted by bora 18t View Post
    Fair enough. I'll answer your question.
    Your never gonna make this frankenunit work.
    Good Luck to ya though.
    Anytown USA
    Heres your answer.
    5 ton condenser + 3.5 ton coil and Air handler= not enough airflow.
    Jul 2010
    connecticut
    Thumbs up
    Which would b low suction, high delta t across evap, low head, high superheat. Nice. Now they have to replace everything. Wow.
    You should already know the answer to this bub. There are no right answers without complete information. See what happened to you?"
    You have the ol "did the job before I looked at the system" alligator bite you on the ass enough times, you will learn the value of complete info every time.
    Walter Matthau
    Hate to be the bearer of bad news but, you sir are not an Air Conditioning contractor.
