Results 1 to 13 of 19
    Jul 2010
    HT (R-11) Oil Loss Problems
    HT (R-11) Oil loss problem
    I add 3-4 gallons of oil to lower sump, Upper sump is full of oil. Let warm up .Start up under good load After twenty to thirty minutes trips on low oil pressure. No oil in lower sump. Is it the solenoid on the jet pump leaking by or internal bearing problems?
    Jun 2010
    U.A. (upper Alabama)
    Quote Originally Posted by uni-ted View Post
    Assuming this machine is low press. does it have a hydraulic purge using comp. oil?
    MEXICO
    reviews the eductors. dehydrators and filters
    Jun 2010
    Quote Originally Posted by servicetrane View Post
    If he had an oil return prob. I would think it would run longer than 20 or 30 minutes before sump goes dry.
    MEXICO
    if the machine works at low partial loads and eductors are lost quickly clogged the oil level another detail that your water temperature at the condenser low
    The Great country of Texas
    Could be low on charge and the oil scavanger of the evap is not working. I have had the jet pump washer inside the jet pump stick. If it has a turboguard purge, valve it off and see if it maintains a level. If it does, the foul gas check valve is bad.
    "I'm from Texas, what country are you from?"
    Jun 2010
    Huh??
    Do you even know what brand a HT is?
    Jun 2010
    Quote Originally Posted by stickerhead View Post
    I think your dead on, on the latter statement, that is if oil is still in machine and not coming out of purge exaust.
    MEXICO
    centrifugal compressor?
    windy city
    ding ding ding!
    \m/
    original member of the racoon brotherhood
    Maryland
    One of the main things to check is your check valve on your purge.
    Jul 2010
    HT Oil Loss
    No it does not have a hydraulic purge it has been upgraded to a Redi purge
