Thread: HELP Please !! MFD , VAV ,CAV
06-28-2010, 09:02 AM #1
- Jun 2010
- 13
Hellow everybody ..
I hope all of you doing great
I need to know when we have to use the following:
MFD : Motorized Fire Damper & FD : Fire Damper
VD : Volume Damper
VAV & CAV : Variable Air Volume & Constant Air Volume
Thanks n advance
06-28-2010, 05:49 PM #2
- Mar 2003
- 7,253
mfd is used when the lifesafety code calls for it for a facility such as a hospital. it is used to isolate one section of a system from another, such as the ductwork from the central station ahu. many times wil be fitted with an end switch.
vd is used when there are multiple taps off one duct. this helps to balance a constant volume system.
vav is used for zoning areas with multiple heat loads serviced by one unit, such as office spaces.
06-30-2010, 03:34 AM #3
- Jun 2010
- 13
06-30-2010, 06:01 AM #4
- Feb 2004
- SW Florida
- 1,243
In all cases you will have to use whatever is specified by the mechanical engineer who is bound by various codes.
