Thread: tube in shell
    NJ
    could you tell me how to clean a tube in shell type condensor?
    Shut off unit, shut off water, pull end bells, brush clean, get unit going.
    Go home, dry off boots overnight, throw away multicolor socks, and throw uniform in wash.
    Oct 2001
    Standard Refrigeration has a service manual PDF that you can download which has a cleaning procedure for shell and tube condensers. http://www.stanref.com/pdfs/Service.pdf
    Generally, brushing the tubes will do the job most of the time. Water quality should also be checked.
    MidWest
    Just a suggestion. I would leave water treatment to a water treatment company. Customer might be a wee upset if you corrode there tubes especially on a big chiller. Or learn it well 1st from someone who knows how to treat water.
    [Edited by referjunkie on 08-11-2004 at 10:30 PM]
    Earth
    Originally posted by referjunkie
    Just a suggestion. I would leave water treatment to a water treatment company. Customer might be a wee upset if you corrode there coils especially on a big chiller. Or learn it well 1st from someone who knows how to treat water.
    Sounds like experience refer.
    MidWest
    Yep.I've cleaned up a few systems that inexperianced techs have gutted. So sad. So sad.
