Results 1 to 13 of 16
    Jun 2010
    Need help with thermostat problem ASAP
    Hi, not a pro and wondering if there's anything I can do to troubleshoot before calling an HVAC company...
    A tenant says that for the past several days they have been setting the thermostat to 74 and the system cools the place to 56. I haven't been able to get down there to take a look myself.
    Thoughts?
    Dec 2001
    Ocean Pines, MD
    You can see how bad they damaged it.
    Quote Originally Posted by Bekind View Post
    Thoughts?
    I'd have to see that to believe it
    Arizona
    Thoughts?
    Sounds like a DIY thermostat replacement job gone wrong. I wonder who will pay the utility bill?
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Jun 2010
    No, the tenant didn't "damage" it.
    No, there hasn't been a "DIY thermostat replacement job".
    Haven't had any problems for years, until about a week or two ago, a power surge caused a problem. The HVAC company was just there to fix that.
    Seriously, is there something I can do.
    Three people looked at it, it's set to 74 and it's freezing cold.
    Arizona
    Call the service company back, should be an easy fix.
    Jun 2010
    "Call the service company back, should be an easy fix."
    They will charge me $228.
    Please, what is the "easy fix".
    A hammer will fix anything if you hit it hard enough. Could be anything as there are no "easy fixes," in our line of work. If your service company was out there and fixed the problem you shouldn't have to call them back. If they were out there and didn't fix the original problem, it's called a "call back," and most companies wouldn't charge you to fix the same thing twice.
    A Lan Far, Far Away in Podunk, Georgia
    Bekind,
    Not often do we hear about a cooling system working TOO good.
    If it's cooling to 56 that's fantastic.
    Now what you need to do is call a service company to troubleshoot why the thermostat isn't controlling the system.
    That's the same thing several people have said but it's the best advice possible given the information we have.
    As said above, this should be an easy fix.
    BTW, Do not be surprised if the problem is not the thermostat though.
    If the HVAC company just worked on it they shouldn't charge anything to come back out and check it for you.
    We all have things go wrong we don't anticipate at times and that's part of the service we provide, to come back and make it be right.
    I WISH my system would cool to 56 on these hot and humid summer days.
    THe problem does not sound complex but all anyone could do is guess at this point and a guess really won't help you.
    Good luck with it, neighbor.
    The reward for doing a thing well... is to have done it.
    Apr 2010
    East of Lyndon's
    I would question the 56 degrees!!!! Easy way to check it out....remove the thermostat!! If it shuts off, replace the thermostat. That shouldn't be too hard of a job if it isn't a heat pump system or a high end thermostat.
    If you can't fix it with a hammer, you've got an electrical problem.
    Washington
    $228 sounds better than a tenant refusing to pay rent.
    Arizona
    Quote Originally Posted by Wendo View Post
    Maybe ,maybe not.
    Southeastern Pa
    Seriously, take the thing off the wall and disconnect it, and see if the system shuts off, if not, you have done all we would risk here in advice.
    At that point, yes, call your service company. Something is telling the system to run, and if that thing is not the stat, then it is having a problem that is beyond website coaching.
    If the system shuts off, replace that stat, once you have determined that there is not a setup program or user programming issue.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
