    Madison, WI
    Just did a call on a 2 year old Trane YSC072A3EHAOAD. The only problem was a loose belt, but as I looked at the unit I realized I did not understand how the refrigerant was being metered into the evaporator. It looks to have a 1/4 to 5/16" line from the outlet of the condenser feeding into a manifold with maybe 5 or 6 tubes feeding the evaporator. Is there a restrictor near the manifold or what?
    There is a restriction in each of the tubes that enters the evaporator.
    orfice in each tube and if restriction occurs just change the whole thing manifold if possible if not complete evaporator
    The information I needed was in my neck of the woods.
    What you seen I think it's an orifice that feeds into a distributor. I say this because there has to be a metering on every unit to drop the temp. of the refrigerant entering the lo side of system. These are the types: capillary, orifice, Thermostatic, automatic, electronic. For a two tonner this had to be a capillary tube wich does not employ a distributer so I exclude that possibility. Therefore, this was an orifice type distributer
