    Jun 2010
    Question Fan on inside unit continues to cycle on and off
    The compressor and fan assembly continue to run on the outside unit , however the fan on the inside unit continues to cycle on and off until air temperature reaches desired setting on the thermostat. Never had this situation before. Suggestions?
    Massachusetts
    Call the installing company or service company. Something isn't wired correctly methinks.
    call a good Licensed Hvac contractor
