Thread: HP-81
    Western New York
    I have only a little HP-81 left, and the Manitowacs that use it are getting replaced. I really don't want to buy another jug... anyone tried using HP-80 as a replacement? I know it's not supposed to be as "hot in defrost" as 81, but any thoughts?
    Experience is what you have an hour after you need it.
    Jul 2000
    Cuenca EC
    HP-81 was only used in the B-Series machines which were produced only for 2-3 years in the mid-90s. They're all out of warranty now so go for it.
    Actually, I played around with a B-600 I had at the shop a while back just to see what the difference was with respect to discharge temps and harvest times, etc. (I know, I should get out more often )
    The HP-80 gave discharge temperatures about 15-20 Deg F lower than the HP-81, but I could see no marked difference in harvest times, ice formation and such. Manitowoc wants to see at least 170 Deg F discharge temps just before harvest and I had no problems getting that.
    I even toyed around adjusting the "non-adjustable" Alco TXV to gain some SH because the HP-80 ran a bit lower.
    I've bought my last 13 pounder........can tell you that.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    Western New York
    Thanks Ice...
    I'll give the next one a try with HP-80. Or if its a good customer, get my last jug of 502 out of the lock box!
