Results 1 to 7 of 7
Thread: true or false
08-01-2004, 07:38 PM #1
If the adjusting spring on the crankcase pressure regulator (CPR) is tightened,the range of refrigerant pressures that can enter the compressor will increase.
true or false.
08-01-2004, 08:26 PM #2
The CPR valve is a close on rise of outlet pressure type of regulating valve. Increasing the spring pressure will increase the valve's controlled pressure setpoint. It will not increase the "valve's" controlled range.
I would have to choose "false".
On the other hand, If you read the question to mean the increase in maximum operating pressure increases the operating range of the "compressor", then I would choose "true".
None of the above.
[Edited by icemeister on 08-01-2004 at 08:37 PM]
08-02-2004, 01:38 AM #3
- Feb 2003
- 1,165
True.
The higher the spring pressure is the higher crankcase pressure has to be to close the valve.Watts New, Ohm My, I been Electrically Commutated. Are U2.
08-04-2004, 12:17 AM #4once again trueOriginally posted by mccool
True.
The higher the spring pressure is the higher crankcase pressure has to be to close the valve.Quote
Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
"We can't solve problems by using the same kind of thinking we used when we created them."
Albert Einstein
08-04-2004, 12:56 AM #5
- Oct 2003
- 566
I think CPR stands for Cardio Pulmonary Resuscitation... :-)
08-04-2004, 12:57 AM #6
- Oct 2003
- 566
I think CPR stands for Cardio Pulmonary Resuscitation... :-D
08-04-2004, 09:19 AM #7
All pressure regulators work that way.
Hey cockroach, don't bug me! ©
www.AskTheDiceman.com
www.TheColdConspiracy.com
www.Pennwood-HVAC.Com
Bring Em Home....
