Thread: gaskets
    do you guys do anything to these reach in cooler gaskets before you install them to get them to hold the door closed right away after instalation. Some of them I have to wedge something heavy up against the door for a while until it compresses enough to where the magnet can hold the door closed
    Flat warm surface. let em lay out there and return to their natural form.
    Sep 2001
    East Stroudsburg, PA
    Fill a sink with hot water.
    Soak the gasket in the sink full of hot water for about three minutes.
    Install gasket.
    A good wallpaper roller can help, also, on SOME gaskets.
    Hang your top two corners, then do the bottom two, then work your way across the top, then the bottom , and finally the sides.
    If the gasket is holding the door open, then the door is either sprung or out of adjustment.
    Jan 2003
    Olathe Kansas
    I use the hot water trick every time I install new gaskets. It would really help if gaskets were shipped in larger containers. Usually all scrunched up when I get them.
    Sep 2000
    Pekin, IL USA
    I wished I would have seen this thread before I went to work today. I didn't think about the soaking in hot water or roller trick. I just installed 15 gaskets tonight on some Randells and Trues. I did the corners first and then just worked the rest in. If your door won't close you either have a misaligned door or you don't have your gasket seated properly.
    Medford Oregon
    Thanks for the suggestion
    I just replaced a scrunched up gasket
    lucky I read this post first
    after hot water soaking, job went slicker than a whistle
