Results 14 to 24 of 24
06-19-2010, 02:32 PM #14
Call them back(the installing co) and ask them a few questions:
Did they do a load calculation on the building?
Did they check the duct sizing of the system at all?
For your part, did you look for the best contractor, or just the cheapest? (just asking)
If the evaporator is freezing up, it will cause the symptoms that you speak of. However, do not expect the new system to "blow harder" than the old system. If the system is set up properly, there should be as little noise, and air speed as possible while delivering comfort. Also, set the fan switch on your thermostat to On instead of AUTO.I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
06-19-2010, 04:42 PM #15I am an experienced, caring, trusted, service provider who solves my customers issues beyond there expectations by educating them and guiding them with value-building options to make excellent buying decisions while building security and wealth for my company, myself and my family.
06-19-2010, 05:18 PM #16
- Mar 2008
- 59
06-19-2010, 08:28 PM #17
- May 2010
- Thurmont, Maryland
- 50
I hear ya. On the East coast mid atlantic region, We had to move away from the 600Sq ft rule of thumb, It kept getting the Co. I used to work for in trouble, now days is strickly Manual J. Around here seems most people want those great big firggin windows,tall ceilings and cut up rooms with no shading or Blinds, some get defensive at the mere suggestion of actually putting up some kinda blinds !! Now days when I'm doing my loads one of my questions to my potential client is "do you plan on having window shading or blinds" 115 degree days!! I bet Attic's are just a bowl full of Joy down there!!!
06-19-2010, 08:44 PM #18
Thrumont,
Does it get that hot in Maryland ? I had fun in Phoenix, I plan on moving back this next spring.I am an experienced, caring, trusted, service provider who solves my customers issues beyond there expectations by educating them and guiding them with value-building options to make excellent buying decisions while building security and wealth for my company, myself and my family.
06-19-2010, 08:47 PM #19
- May 2010
- 50
Not 115 deg. Hot but some years August can be around 100-102 deg for a good portion of the month, but for the most part it's Humid as Hell from late may to September.
06-19-2010, 08:52 PM #20
I hate the humidity. I was down in Virginia this time of year going threw school and it was like 90 to 100% humid back in 92.
06-19-2010, 08:53 PM #21
You can't assume the tech knows what he is doing.
He might, but............Hey cockroach, don't bug me! ©
www.AskTheDiceman.com
www.TheColdConspiracy.com
www.Pennwood-HVAC.Com
Bring Em Home....
06-20-2010, 12:04 PM #22
06-26-2010, 05:19 PM #23
Professional Member*
- Jun 2010
- Philadelphia PA
- 2,139
To answer your question directly, Yes the tech was right, when you closed off the two easy paths for the air to go, you reduce the airflow to the point where the coil froze!!!!!
Closing the Bstm ters sounds logical but it doesn't work begause the resitandce in the duct for the rooms that are not being served is too much for the pressure in your fan to overcome.
You need someone who understands duct design/sizing to help you. too bad the istaller didnt seem to be that person.
06-26-2010, 05:21 PM #24
- Jun 2010
- Philadelphia PA
- 2,139
PS the 5 ton unit means that you need to move even more air and hence the small duct system was even more challeneged
Dude that was awesome!!!
