    Jul 2002
    Its an old beauty. Did Singer get out of the A/C business. I can't get any info(Wiring Diagrahm)on these hogs. All I can tell is its a 1978 Package unit. 2 1/2 ton AC and 100,000 btuh input nat gas.
    Problem was a bad T-stat, but noticed power vent motor on all the time even in cooling mode.Looks like somebody replaced it recently. No power to W terminal.
    Chill
    St Paul, minnesota
    contact McQuay Intl. They bought them out quite a few years ago. On some singer & older carrier units in that era draft fans were factory wired to a "B" terminal. If you had a manual changeover stat they ran all the time that stat set to heat. I've seen units running in the summer when an auto changeover stat was installed LOL
    Jul 2003
    Fort Worth, TX
    I think some older gas packs did run the draft blower all the time whether there was a heat call or not. Lennox comes to mind.
    Actually you need to contact International Comfort Products. McQuay sold of the residantial line atleast 15 tears ago.
    Jul 2002
    Thanks guys, its worth a couple of phone calls, I might get another call from this customer some day.
    Chill
