Results 1 to 2 of 2
    Jul 2003
    Fort Worth, TX
    Anyone found a good source for non-penetrating roof edge railing for fall protection on a flat roof without a parapet wall. It has to be 42" tall with a railing at 21" and extend 3' in both directions from the edge of the piece of equipment you are servicing. This info is in the IMC.
    I found KeeGuard, but not many others. I've seen everything from professional systems to 2 x 4s screwed together.
    This protection is being strictly enforced around here since an inspector nearly went off a roof.
    Thanks.
    Try Portable Pipe Hangers ph. 713.672.5088. Their big thing is stuff on the roof that doesn't penetrate the roof.
    Good luck!
