Results 1 to 13 of 13
Thread: Mcquay Screw
    Jul 2003
    Question
    Does anybody have info on Mcquay Screw compressor. Model SAL175QA13DA Im lookinin for compressor piping configuration. Internal operation on a ALS090 R-22 Screw chiller. If you could help Thanks Could not find it on my Mcquay CD.
    Oct 2002
    Maybe here?
    http://www.mcquay.com/eprise/main/Mc..._Screw_120-400
    We just picked up a 150 at a hospital..cool machine..breaks down weekly
    [Edited by sonc on 07-28-2004 at 04:01 AM]
    I work with the Chiller Whisperer...
    call the tech line where they are built in Virginia...540-248-9201
    dear Chillerguru, did you find required thing?
    I'm asking because I'm looking for manual for this compressor.
    Can you help me?
    Oct 2007
    california
    What do you want to know? This is Stargate-rotor compressor with suction on side discharge at top. liquid injection on side mid compressor econ.at rear of comp.oil cooler at bottom front and dual slide valves in 45*from each other. has pump at rear on rotor.oil sightglass on top mid way.orignal set up across the line start with no oil seperator.retro cek kit softstart and oil seperator.wasn't the best and they were not lasting very long.Although I did come across one that had about 8 years of operation with decent amount of runtime although in my experience wasn't common.New mcquay comp totally different but ALS series didn't fare to well for Mcquay. So far the new style of Mcquay screw AGS ok I just dont care for microtech 2.(coral control).Still prefer Trane RTAA any day.
    It is necessary to replace defective compressor and install new one. Vendor sent new unit without oil, absolutely dry.We have no information about working of oil circuit. (Through what orifice fill the circuit? What we have to see in oil sightglass when compressor is working? How does oil circuit works?)
    Aug 2000
    Does it have a CEK on it?
    Your poor planning does not constitute an emergency on my part!!!!
    Metro ATL
    Hopefully after 5 years, he has been able to locate the info he needs.
    Jul 2003
    looking for compressor breakdown and operation of capacity control, weather slide valve or piston unloading.
    1) Mcquay chiller M# ALS090AS27-ER10 S#stnu990600101
    Compressor M# SAL175QA13DA Style #MR74165703
    Mar 2009
    Mid-Mo
    Go download the iom from their website, it will show what you're looking for.
    Additional infractions may result in loss of posting privileges.
    summerhelp
