Results 1 to 11 of 11
    Jun 2010
    antique carrier weathermaker
    i recently aquired an old still in use ac unit from a diner that closed recently . the diner has been in operation since 1935 . it had 2 owners , and the latest owner had it since 1962 . the owner couldn't tell me much about it , only that it still ran, he turned it on before i unhooked it. he used it occasionally. it's a carrier weathermaker. there are no tags or vin numbers on it . ididn't want to take it apart unless i really have to. maybe an id number inside. the ac unit was there when the diner was purchased in 1962 by the second owner. it stands 7 or 8 feet tall and about 3' by 3'. an inside model color green. i'm having trouble finding any info about it . maybe someone can help . my name is corey crouse at
    Last edited by BaldLoonie; 06-15-2010 at 06:32 PM. Reason: please put e-mail address in your profile
    Jun 2009
    Northwest IN/Chicago
    Oops.
    Last edited by Gus-Herb94; 06-16-2010 at 12:54 AM. Reason: Was thinking of the wrong thing
    Nov 2001
    Long Beach New York
    This is about the oldest Weather maker literature I can find.
    Howell, Michigan
    I have seen what you are talking about...............They used Careen 7 as a refrigerant!
    Feb 2013
    Wellsville, PA
    1935 Carrier Weathermaker
    That is a real collectors item. Do you still have it?
    Quote Originally Posted by corey crouse View Post
    Dec 2015
    Antique Carrier Weathermaker
    Quote Originally Posted by Nixonfan View Post
    I have one that is original and still works great. No idea what they are worth, but I have to take it out of service due to city utility issues. Any ideas? Thanks Steve
    SE Michigan
    Thats awesome!….I would restore it if it were mine.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Dec 2015
    It actually works great. I believe it is virtually all original. I had to change a hose inside of it this last year, but other than that it has been fine for the last 15 years. It has just become too expensive to run on city water.
    Jan 2016
    Arizona
    Very cool to see old/antique hvac stuff in such good shape. I think I saw this or one very similar for something like $10k
    Dec 2015
    Quote Originally Posted by RayKwonDoe View Post
    Wow, I think it is probably pretty rare. It might be worth that if the right buyer came along. Thanks for the info.
    New Mexico
    Those were a good choice where there was limited access for equipment and ducts. Just needed condenser water. I had some way back in department stores. Mine were R12 and quiet running.
    I installed a self contained Trane 10 years ago but it was ducted and had an air cooled condenser also ducted.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
