Results 1 to 8 of 8
    Jul 2003
    What is the best cleaner for evaporator coils that you have used? I am currently using a pink acidic type hi-foaming cleaner to clean out impacted coils and a green alkaline base for every day cleaning.
    I have one evaporator coil that I have cleaned 3 times now and it is still restricting the air flow. I have sprayed this coil with the foaming type cleaner and a hose and removed tons of hair and dirt but still it is clogged. I need to pull this coil tomorrow and it is going to be a pain the way it is installed and I need to use a better cleaner. Any suggestions?
    [Edited by workhorse on 07-26-2004 at 07:52 PM]
    Jul 2002
    Franklin
    I like the PLUS made by Vapco. Also they make a blue evap and electronic air cleaner chemical that is awesome. Priced slightly higher than most but is quality.
    Grottoes VA
    Would it not be cheaper for HO to replace coil than to charge him/her multiple cleanings? Just curious.
    Jul 2003
    Doing it for an apartment complex. Probably would be cheaper but this particular a/c is only a few years old. Former maintenance staff was very neglegent and never changed filters, resident pulled filter and was to lazy to pick up new one at office.
    Dec 2003
    Nevada
    Vapco!
    Quote
    “Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
    "We can't solve problems by using the same kind of thinking we used when we created them."
    Albert Einstein
    Jan 2001
    So.Cal
    Chemicals work well to some degree but the fumes are horrific. Nothing beats a physical cleaning, remove and replace.
    Doesnt anyone mfr a mini steam cleaner for such a job as this?
    Jan 2003
    Beaufort, SC
    When they are that bad I pull them seal up the ends and take it to the car wash.
