Results 1 to 8 of 8
Thread: Mccall pass thru unit
07-26-2004, 09:01 AM #1
Professional Member*
- Nov 2001
- East Texas
- 832
Need to replace cond. unit.
Comp was replaced about 5 years ago. It is a copeland
JRL4-0500-IAA-958
The evap has a pump that pumps the condensate up to a pan on top. There is a coil of copper tubing in the pan that the hot gas flows thru before it goes to the air cooled condenser.
What cond unit should I use for replacement?
Anybody have exp. with this puppy?
07-26-2004, 09:02 AM #2
- Nov 2001
- East Texas
- 832
Mccall
Model: 4001 RT
Serial: M289 74
07-26-2004, 09:53 AM #3
- Feb 2004
- Medford Oregon
- 807
the unit in that case is Copelans's CopeEvap unit, used in self contained units that have minimum condensor or poor airflow. A standard unit will usually go off on high head. Get the Copeland unit model (probably FBEH-0050) and go to your Copeland distributor and get cuurent CopeEvap model. Usually not stocked, so be prepared to wait. Or you can just change commpressor which won't be an axact fit.
07-26-2004, 09:57 AM #4
- Nov 2001
- East Texas
- 832
United refrigeration reccomends a MBFH-0050-IAA-109
Will this work with the original evap?
07-26-2004, 10:49 AM #5
- Feb 2004
- Medford Oregon
- 807
MBFH-0050-IAA not a CopeEvap unit, will probably not work
the "E" as 3rd letter represents CopeEvap
they are probably reccommending that based on nominal HP and don't know what CopeEvap is
if your unit was an FBEH-0050-IAA then Copeland suggest an M2EM-0048-IAA R134a unit (can use MP39 if desired)
07-26-2004, 11:02 AM #6
- Nov 2001
- East Texas
- 832
Mccall says they are 90% sure that the original cond unit was a FBAM-A050-IAA
What does this cross to?
07-26-2004, 11:16 AM #7
- Feb 2004
- Medford Oregon
- 807
the FBAH-0050-IAA crosses to MBFH-0050-IAA
the FBAH did not have facitities for coppper tube in drain pan so double check with with manufacturer. if it really was an FBAH the the MBFH will do fine
07-26-2004, 11:54 AM #8
- Nov 2001
- East Texas
- 832
what do u mean by facilities
Are ther cut sheets on these 2 diff. models?
If i use the MBFH can I just pipe in the hot gas coil that goes to the drain pan?
