Results 1 to 10 of 10
    Aug 2001
    vancouver
    Confused
    restaurant kitchen with all the grills, stoves, frequent opening of backdoors, hot water on the pre-wash sink, etc..etc..rooftop a/c just couldn't handle the LOADS...
    is there any way that the walk-in coolers and freezers can somehow help cool-down the area...i.e small opening plus fan to throw cold air???
    is it dumb question???
    Nov 2001
    Seattle, WA
    Yes
    - Alexis de Toqueville, 1835
    hahahahaha
    hahaha
    haha
    ha...........
    Part of the hahahaha problem, hahahahahahahahhaha hahahahhahhahahahahahahhahahahhahahaha, is there airflow in the back.
    Typically a kitchen has exhaust REMOVING AIR from the space and to replace that, they have MAKE UP AIR bringing in fresh air off the roof.
    There needs to be a balance. Otherwise there will be a problem.
    If the kitchen becomes negative, it will suck cooled air from the seating area and draw it up the hood and away goes the expensive air.
    On the other hand, if it is over charged POSITIVELY, it will pressurize the seating area with stinky cooking ordors.
    Bummer.
    There needs to be this balance.
    A lot of restaurants are NOT balanced to where they should be.
    A little bit off and there goes your ability to cool the seating area.
    Just a little bit off.
    You could always just leave the freezer door open
    Yes, you can do that, open the doors on the walk-in's and put box fans there blowing into the kitchen.
    And ....ahhhhhhhh don't forget to take all the food out and store it somewhere else, somewhere that keeps it cold enough not to spoil. Good luck in your quest.
    Hey cockroach, don't bug me! ©
    Earth
    You guys always miss the obvious. Just tear down the walk in, hang a coil in the kitchen. Look at the benefits, never have to put any food away, the kitchen help will stop *****in about how hot it is, and the waitress’s will stop hanging out with the chef. On top of that the electric company will start buying you Christmas presents.
    NJ
    Since you are a 3rd year apprentice its dumb.also some of the replies get close to the question `cause of no regard of your profile.
    Aug 2001
    vancouver
    ok.ok.ok!!!
    i got the message. so what should i do (the right way) then?
    ok.ok.ok!!!
    Your asking this question AFTER reading my post?
    I dont believe it!
    I am not the consumate expert on restaurant air balancing of exhaust and A/C.
    However, if you read my post AGAIN, and follow what I wrote, you will be so close to dead on you will even "squeak"!
    Enjoy yourself.
    Oct 2002
    throw 10 tons of dx in the mua...there. that oughtta do it. next question..
    I work with the Chiller Whisperer...
