Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 73
  1. #27
    Fit a casing of 16-18" in diameter around the BOP.
    Make that casing extend to 121 AT. (4 k )
    Fill the casing with cement,the pressures will do the rest.
    The well will be capped.
  2. #28
    Float'N Vally, MS
    Quote Originally Posted by ga-hvac-tech View Post
    If I can find it, I saw a cartoon (photoshopped) of a barge lowering the domed capital building from Wash DC (upside down) into the gulf to plug the leak... sounds like a good use for a worthless building that generates too much trouble anyhow...
    Maybe B.O. will propose this!
    He is giving everything else away!
    Life is too short, Behappy!
    TFMM
  3. #29
    Float'N Vally, MS
    Quote Originally Posted by the mojo View Post
    The casing would most probably have to be 60" or better to fit over the BOP's, but it could be belled. That being said, I liked the theory of a steel "Dome of Silence" being built at a ship yard and lowered over the whole thing on a string of casing.
    TFMM
  4. #30
    Jun 2009
    Bakersfield, Ca
    This will work!
    We hire all illegal immigrants and supply them with goggles and big gulp cups and straws! We pay them per cup load of oil, and then when they die, we collect our money!
  5. #31
    Oct 2006
    The Beach
    The pressure coming out of that 21" pipe is close to 25,000 lbs.
    Flanges are available with sets screws but it's hard to make this work when it is a mile down. They might not be able to completely
    stop the oil but should be able to slow it down in a few days. The relief wells have worked in the past. They will bore into the leaking well and pump concrete into it with what ever pressure it takes. That mile down is the problem. If the environmentalist would let us drill closer the the shore it could be handled.
    Blue Fox
  6. #32
    Nov 2008
    Paradise
    Are they flanges or are they male and female threads? Thats what they used on the TV show Black Gold.
  7. #33
    Jan 2010
    Port Allegany, PA
    I think we should save our thoughts for our area of expertise. Let the oil producers and experts fix the leak. Give them time and support and it will get fixed. Every day it leaks costs them more money. They will come up with a solution eventually. I hope Bp has lots of money to deal with the clean up and economic problems it has caused.
  8. #34
    Jul 2009
    Connectitaxed
    And the time keeps ticking away!
    "Time to nut up or shut up!" Tallahassee - Zombieland
  9. #35
    So much damage has done! BP should provide a lifetime benefits $$$ to the victims who suffered from that oil leak.
  10. #36
    Nov 2008
    Paradise
    Quote Originally Posted by alltruetech View Post
    BP is going under. They don't have 20 billion to give. The tax payers are going to pay for it.
  11. #37
    Jun 2010
    Northern VA
    Actually the fix is quite simple. Put a wedding ring around the pipe and it will stop putting out!
  12. #38
    Jul 2009
    Connectitaxed
    Nuke it!!!!
  13. #39
    Howell, Michigan
    Quote Originally Posted by Prettyricky View Post
    we can put a man on the moon,
    We've been to the moon? Are you kidding me? No way! Personally that was another fraud against America.
