06-12-2010, 03:37 PM #1
- Jun 2010
- Kingston PA 18704
- 42
What is the best Carrier Infinity combination for my install?
Hello everyone,
I have narrowed down my choice of new HVAC system consisting of Carrier Infinity Controller, MVC 080 furnace, 25HPA636 Heat pump and best matching coil for high efficiency and tax credit. I also want to add a Carrier Humidifier (infinity controlled) if not too costly and only if it works as designed.
The furnace and HP selections were based on a load calc and specified by more than 1 Carrier dealer/installer. The problem is they varied on exact model numbers and indoor coil selection.
My question is...what is the exact combination or model numbers that would garner the highest possible efficiency rating (and gov't tax credit) for this size furnace/HP combination?
Also what humidifier would work best and be controlled by the Infinity Controller?
I want to make sure that when I sign the proposal, I know exactly what is being installed and that it will have highest eff and be tax credit eligible.
Thanks,
Chuck Simonds
06-12-2010, 03:39 PM #2
Banned
- Oct 2003
- Washington
- 7,405
Dash to be along shortly
06-12-2010, 05:15 PM #3
For highest efficiency, have the two companies produce AHRI certificates for the equipment they're proposing in your home. That will give you the actual model numbers of matched equipment. The search they do to get that certificate can be modified to include only tax qualified systems.
