Results 40 to 50 of 50
Thread: appliance guys?
07-24-2004, 02:18 PM #40White has to do with purity...maybe it's a sign!Originally posted by Diceman
More news, if ya run it on the whites cycle it doesn't spin out on the regualar last cycle either........wat up wit dat??"The American Republic will endure until the day Congress discovers it can bribe the public with the public's own money.
- Alexis de Toqueville, 1835
07-24-2004, 03:57 PM #41
Hey, does it fill when you select cold water only? Have you changed the water valve lately? With the new symptom you're giving us it could be a couple of things.
07-24-2004, 04:27 PM #42
WH, not sure I'll check it out, thanks.
Hey cockroach, don't bug me! ©
www.AskTheDiceman.com
www.TheColdConspiracy.com
www.Pennwood-HVAC.Com
Bring Em Home....
07-24-2004, 08:50 PM #43
Dice I was hoping you would get it on your own, but I guess not. So I will have to give you a hand. Multiple choice of course, so you may still retain your manly ego.
1 Operator error
2 The goat is f##king with you.
3 One to many trips behind the shed, or maybe one to few.
4 Intermittent door or balance switch.
07-24-2004, 08:58 PM #44
Put an insulated jumper across the final spin terminals. If this doesn't work try a new "wig-wag". Let us know how this turns out.
There is nothing more frightful than ignorance in action....Mark Twain
07-25-2004, 10:24 AM #45
- Nov 2003
- Wisconsin
- 452
Originally posted by workhorse
Now guys, listen here. If it was the EFFIN timer it wouldn't work in a normal rinse or a normal spin. How about the initial fill. If you all would just follow your own advise and just LISTEN to what was said, "My washer doesn't spin out in the rinse, the extra rinse that you have to set". Now if it didn't work and other time I might agree, but most likely not. 95 times out of 100 it will NOT be the timer, it would be a switch or something else.
Could still be the timer. I've replaced lot of bad Maytag timers over the years that just5 forget part of the cycle. Just because the timer motor runs does not mean that the little switch contacts inside are not worn to the point of not making contact when required.
07-25-2004, 11:53 AM #46
- May 2004
- 87
didn't read all the answers so this is probably a repeat, but it sounds like the selector switch.
07-25-2004, 11:54 AM #47
- May 2004
- 87
didn't read all the answers so this is probably a repeat, but it sounds like the selector switch.Thats where I would start, and since it sounds intermittent I would jumper it and try it a couple of times if that cures it just replace it.
07-25-2004, 11:56 AM #48
- May 2004
- 87
wig-wag is a pre-1984 whirlpool partOriginally posted by HVAC Pro
[Edited by maintmankc on 07-25-2004 at 12:00 PM]
07-25-2004, 03:12 PM #49I believe he was jokingOriginally posted by maintmankc
MOST people think you are just making up a name when you say you need a wig wag, like a whachamcallit or thingamabob.
07-25-2004, 05:54 PM #50
You have to admit. Wig-wag was a cool part name. I only know about it because my one and only appliance repair (on my own washer) was replacing this part. A set of solenoids. Great idea.
