    Jun 2009
    Albuquerque NM
    Duct sealing for unexposed ductwork
    I'd like to check into getting my ducts sealed but I have mostly unexposed ductwork due to the flat roof. What do you think of the aerosol duct sealing? Are there any other ways to seal unexposed ductwork?
    Sep 2009
    Arnold mo
    Maybe look into getting some exterior insulation installed on that flat roof. That would help protect the ductwork from extreme temps & make the leakage less of an issue.
    Jun 2009
    Albuquerque NM
    Quote Originally Posted by tipsrfine View Post
    Yeah I was thinking about that too. I mean, if the air leaks out of the duct it can only go into the roof truss space which is about 2 ft high. I know that space gets real hot as I've had to make openings in it.
    I may need the roof done soon so that would fit in nicely.
    might get duct leak test to see if it is worth persuing
    Jun 2009
    Albuquerque NM
    good idea
