Thread: York screw YCAS
    Apr 2003
    South Carolina
    I have a air cooled srew machine and the #1 compressor is leaking oil on the discharge plate. Tightened all the bolts and still leaking. Can the gasket be replaced in the field
    Aug 2000
    Under my tree
    What are you refering to as a discharge plate? Where the service valve bolts to the compressor. You can probably buy most of the gaskets and o-rings for this compressor from York.
    Apr 2003
    South Carolina
    york calls it a discharge cover which is part of the main compressor housing
