    South Dakota
    Question
    I will be installing a RUUD Model UGRA 92% efficient furnace in a 2200 SQ FT new house and am wondering if I need to install an April Aire whole house humidifier?
    I currently have an 80% Carrier with a April Aire 600 that has been very comfortable in the dry winters in the Midwest.
    A friend told me that once he installed his Lennox 92% efficient furnace in his house he stopped running his April Aire unit because he felt that the upgrade to the 92% efficient caused his house to feel more humid and comfortable in the dry winters.
    Any one have opinions on whether I will need a April Aire with my upgraded efficient furnace?
    Dec 2001
    Chicago, N/W burbs
    Yes, you need a humidifier. As you heat cold air the relative humidity takes a nose dive. Your friend should get a good hygrometer and see what the actual humidity is. He's probably having to keep the house temperature unnecessarily high to compensate for the dryness.
    R2B4BTU
    Dec 2001
    Chicago, N/W burbs
    If you still have the owner's info packet for your Aprilaire there is a good explanation on why you need a humidifier. Get it now, you'll appreciate it later.
    No static shock
    No dry throat
    No shrinking woodwork
    You'll be comfortable at a lower t-stat settin thus saving money
    [Edited by otto on 07-21-2004 at 09:09 PM]
    R2B4BTU
    South Dakota
    Smile
    Otto-Thank you for your suggestion and confirmation.
    In short tell your friend that he is full of crap.
    If you have trouble doing this come back here. We can talk you through it.
