Results 14 to 26 of 32
    Apr 2002
    Dry air consists of oxygen O2 with a molecular weight of 32 and nitrogen N2 with a molecular weight of 28.
    Water is obviously H20 meaning two hydrogens ( molecular weight of 2) and one oxygen molecular weight of 16. Therefore a water molecule 'weighs' 18.
    Steam with a weight of 18 is lighter than something that is roughly 0.2x32 + 0.8x28 = 28.8. Air is actually a bit heavier however the math is simpler with 20% oxygen and 80% nitrogen.
    http://www.ductstrap.com/
    Apr 2002
    Originally posted by NormChris
    Let's see now, the clouds are a collection of water vapor and they are located where?
    We always seem to come back to clouds Norm. They are water droplets. Vapour is invisible. But what the hell keeps the droplets up there?
    Apr 2003
    Iowa
    Please enlighten us with the answer Norm. Inquiring minds want to know.
    There are 3 ways to do anything in life; Good, Fast, Slow: You can pick any 2.
    Jan 2003
    Hmm
    Trick question Norm? Temp and pressure of air dictates water vapor.
    Warm air holds more water than cold air.
    clouds,
    When air rises, it expands and gets colder.
    The colder air cannot hold as much water as warm air.
    As the temp and air pressure continue to drop, tiny water droplets grow together into clumps called cloud droplets.
    At this point,the air becomes a visible cloud.
    So it would seem to me,temp diff. Fog and cloud are same.Colder surface,fog. Warmer surface,cloud.
    But i'm probobly way off!
    South Dakota
    No trick, just common sense and good reasoning. Give it more thought.
    Apr 2003
    Iowa
    I guess this illustrates the value of further education. However, how many techs REALLY need to know this on a daily basis?, just curious is all.
    Apr 2002
    Clouds which consist of water droplets are a bad anaolgy.
    Have to look at molecular weights, daltons law of partial pressures, vapour pressure of water and ideal gas law to try to work things out
    South Dakota
    Carnak, what is the density of a cloud? In the English system, not the metric system.
    South Dakota
    How about if I use steam leaving a tea kettle? Or will you have a problem with the fact that it is at too high a temperature?
    Let's go back to the fog. The reason fog is on the ground is because it (water vapor) was formed on the ground. When we see it, it is actually rising because it is lighter than the air around it. We see it because it is being replaced as fast as it rises and disappears. So fog as water vapor is a good example of water vapor being lighter than dry air.
    When teaching people it is more useful to provide practical examples they can relate to than spend a great deal of time getting highly technical. Getting technical is fine but it all comes together faster when you can provide an example people can immediately identify with.
    Richard Feynmen (sp) one of the greatest physics professors was well know for just that. When he gave lectures to his students the auditorium was also packed out with liberal arts students. That is how plain and simple he made physics.
    Apr 2002
    If you collected water droplets it would be a little shy of 62.36 pounds per cubic foot.
    Cloud is droplets, what keeps them up there I don't know, but it is not density lighter than air.
    What keeps dust in air?
    [Edited by Carnak on 07-23-2004 at 11:42 PM]
    Its comparing Apples and Oranges really...
    Liquids is Specific Gravity.
    Gases is Vapor Density.
    Water has a specific gravity reading of 1. Liquids less than 1 are lighter than water, vice versa for heavier
    Air has a vapor density reading of 1. Gases less than 1 are lighter than air, vice versa for heavier as well
    Hey mosquito, quit biting (slap!!) me...
    Anyone like Josey Wales?
    C'mon, you know I'm right!
    Apr 2002
    I always thought fog meant air temp dropped below its previous dewpoint meaning water condenses out. Back to what keeps droplets suspended.
    You are seeing droplets, a liquid, not the invisible vapour.
    THe steam off the kettle is saturated and is in equilibrium condensing/ re-evaporating. Saturated steam comes out of kettle, contact with surrounding air mometarily condenses some, however the presence of surrounding air means the droplets are free to revaporate as long as surronding air is not saturated. Sort of like a Dri Steem Humidifier.
    When you breathe in the winter you can see your breath because the vapour is condensing, if it dissapears it has re-evaporated.
    Just as much vapour in breath in the summer but you don't see it because it is not condensing.
    My real point to this whole matter is that vapour is invisible.
    With clouds, there is a temperature drop with elevation, however there is also a barometric pressure drop with elevation. At a higher elevation, with the lower barometric pressure, more water can evaporate at a given temperature.
    Its all to do with Daltons Law of partial pressures
    [Edited by Carnak on 07-24-2004 at 12:08 AM]
    Apr 2003
    Iowa
    Well, then I thought right.
    But thanks LMTD for the little lesson, that's why I like this site. I work on residential mostly, the biggest I really see is 10 tons but it's neat to see what else needs to be considered on a bigger scale of things. Just once I'd like to work on a huge chiller, just to get familiar with a little of everything.
