Results 1 to 13 of 32
    South Dakota
    Which is heavier, dry air or water vapor?
    Jul 2001
    Buffalo N.Y.
    A
    Apr 2003
    Iowa
    I vote for dry air.
    There are 3 ways to do anything in life; Good, Fast, Slow: You can pick any 2.
    dry air
    Oct 2002
    Yo.... Here!, I'm right here..
    Talking more trickery
    just to be different it depends on the temperature.
    Norm I know you can work the psychrometric calculator could you explain it to us sometime, if you already haven't.
    South Dakota
    Let's see now, the clouds are a collection of water vapor and they are located where?
    Oct 2002
    Talking ah sheeeeeeeeee it
    see I knew you were going to pull something like that.
    dah hilt a hilt
    South Dakota
    Re: ah sheeeeeeeeee it
    dah hilt a hilt
    Ok, so how do you explain fog on the ground?
    Mar 2002
    Richmond, Virginia
    Which is more important? 6% net profit or 2% gross profit?
    Mar 2002
    Richmond, Virginia
    Ooops wrong thread!
    South Dakota
    If I knew the answer to that I would still be a contractor!
    Apr 2003
    Iowa
    I belive most look at gross profit.
    Because over-head can be reduced which would in turn increase net profit. In reality they are both important but a bank or something of the sorts is going to be looking more at gross profit.
    [Edited by I_got_ideas on 07-20-2004 at 10:39 PM]
    Apr 2003
    Iowa
    Fog on the ground means there is no dry air, the air is saturated.
    Forgive me, grasping for staws to justify my answer but it sounds good.
    You know, that sounds real good now that I read it again.
    [Edited by I_got_ideas on 07-20-2004 at 10:40 PM]
