Results 1 to 13 of 18
Thread: CPC sensors
09-04-2006, 10:22 AM #1
I have noticed some companies using a different sensor to replace failed CPC sensors. There is no name or markings on them. A friend of mine says his company starting using them because they are a 1/3 of the price of CPC, but has no idea where they are getting them from.
Anybody have any idea who makes them and if you have used them, have you had sucess with them.
09-04-2006, 12:53 PM #2
juneair,
what is a cpc sensor.
I'm trying to soak up as much as I can.
I'm a typical hvac tech that gets more thrown at him than one knows.
Learning everyday so please be easy on me
Thanks for your educational responce
09-04-2006, 01:11 PM #3CPC stands for Computer Process Controls. This is a company that manufactures computers if you will that can control several aspects of any HVACR system.Originally posted by travistee
juneair,
A sensor is a device that measures temperature. Whether it be discharge air, discharge line, suction line, outside ambient, etc...........
Juneair - We did not get involved in ordering our own parts - sorry, unable to help.
09-04-2006, 05:19 PM #4
We use them
They have grey leads and they work great.
Sorry don't know the maker though.
09-05-2006, 12:40 AM #5
- Feb 2003
- 1,165
The CPC sensor is a common 10K ohm sensor, we used a compatible sensor made by Basys Controls, Middleton Wisconsin, ph.(608)836-9034. fax. (608) 836-9044
I happened to have 1 sitting in the kitchen drawer for the last 5 years unopened, hence the detailed info. They worked fine initially but did not have the same life expectancy as a CPC sensor. Don't have time to supply a picture but they do not appear to be sealed as well where the wire leads meet the sensor (can't tell due to wire spring on sensor, could likely be helped by a few wraps of tape or heat shrink to keep out moisture)
They were cheaper but some had to replaced within 1 year or less!! They did generate more income because of that but....could piss of a customer with that kind of failure rate.
There are likely a lot of companies that make 10k ohm sensors,you can swap 1 for your Cooper electro therm sensor if you can solder together the right connector/plug-in.Watts New, Ohm My, I been Electrically Commutated. Are U2.
09-05-2006, 03:22 AM #6
We use some with yellow leads, don't know mfg.
I still like green.
09-05-2006, 03:50 AM #7
- Dec 2004
- Sunny So Cal!
- 649
Geez Mccool clean out yer drawers fr petes sake....Originally posted by mccool
There are likely a lot of companies that make 10k ohm sensors,you can swap 1 for your Cooper electro therm sensor if you can solder together the right connector/plug-in.Look, just do your job, stay outta my way and we'll get along fine.
Teach your kids to respect themselves and others with your actions- these little baboons will imitate you like it or not.
05-06-2008, 03:46 PM #8
- Aug 2006
- Wisconsin
- 26
ACI Sensors
Try Automation Components (ACI). They have green lead versions to match the look of the CPC sensors....
Enjoy your day!
05-07-2008, 10:08 PM #9
I've used 3 different Green lead type, not sure where they all come from but they're different makers. I also have a few with orange leads, there's a flat/curved spot on the sensor which makes mounting it to a pipe better. kinda like the curved spot on some danfoss TEV bulbs.
MikeSig removed by mod. G-Rated site
05-08-2008, 09:55 PM #10
CPC sensor to a Danfoss Sensor to a Novar Sensor To A Comtrol Sensor, If you dont know the differerance then there's something wrong
05-09-2008, 02:03 AM #11
05-09-2008, 06:03 PM #12
Sensors are 10K thermistors, not resistors. There is a "10K Type 2", and a "10K Type 3". As you may know, thermistors are non-linear devices. A change of x ohms in the measured resistance does not always correspond to a change of y degrees. It depends where on the range of the device you are.
Most controllers have a built-in idea of the curve for "10K type 2" and/or "10K type 3". Which is why they can give an accurate temperature reading even if thermistors are not linear.
Type 2 and Type 3 do not have exactly the same curve. If the application requires precision, you need to use the right type. If in doubt, ask the manufacturer what 10K type is supported by their controllers.-------------------------
CO2 Racks Rock !
05-10-2008, 03:42 AM #13
!!!! Resistor !!! not resistor!!! maybe resistacne has a value??
