Results 14 to 25 of 25
    Kaufman county, Texas
    The fuses may be the original problem. I suggest wiring around those pesky troublemakers.
    JUST KIDDING!
    But an 8k winder shaker may not pull much more juice than an old 5k, and it can throw air further. That is important in winder shaker selection. Of course, you might have to miss an episode of "THE LOVE BOAT" , but that is prolly not a problem for you as you seem to have found the perfect "LOVE SHACK" anyway.
    And remember these words young man:
    "A fire extinguisher in hand is better than, well if there was a fire or something I guess".
    Never forget it.
    I draw all my schematics in crayon now. If they cannot always be correct, they can at least be colorful.
    Service calls submitted after 3PM will be posted the next business day.
    I give free estimates [Wild Ass Guesses] over the phone.
    I am not in business to make money from other people so that I can afford to work for you for free.
    If the fall is over, mmmm let's say, 6 feet or so,.. I do not 'bounce' very well.
    Jun 2009
    Northwest IN/Chicago
    Quote Originally Posted by Tool-Slinger View Post
    JUST KIDDING!
    Never forget it.
    Energy star rated window shakers tend to draw 1 amp less then non E-star models.
    5000 BTU units usually use 5 amps or less, and non E-star 8k units are about 7 amps.
    Quote Originally Posted by Gus-Herb94 View Post
    Did I read that right?
    You are basically saying that he could upgrade to an 8k and probably only gain about 1 amp. That sounds like a good deal.
    Jun 2009
    That and these things often draw less power than the rating says they will. Even a 10,000 BTU energy star rated shaker doesn't draw too much power - 8.4 amp rating for an LG model I saw recently.
    Jul 2009
    Connectitaxed
    I would be more worried as to why he is having fuses blow than to find a way around that happening. I wonder what the wiring looks like if you are still using fuses.
    "Time to nut up or shut up!" Tallahassee - Zombieland
    Lancaster PA
    Lot of those old places. Are 30 amps total for the whole place. As in 3600 watts for the whole apartment.
    Doesn't take much to draw that.
    Jul 2009
    Connectitaxed
    True...my house was similar when I first bought it. The wiring would crumble in my hand as it was pulled out. Upgrade the electrical and end the worries.
    Nothing lasts forever.
    Thank you all for your funny and valuable comments.
    I got an 8k window type from Costco for $190 and everything seems to be fine so far. It's an e-star Sharp AF-S85RX. It draws about 7 A max per the spec.
    By the way, my fuses are the screw-in type.
    Jan 2010
    Quote Originally Posted by pwanghk View Post
    Might want to use slow blow fuses.
    Central NJ
    It's not uncommon for garden style apt buildings with 30A or 40A mains supplying a 4-8 circuit subpanel in the apt. This was common in the 50-60's and are prevalent today. I would have a qualified electrician check to see if you have sufficient room to add an additional circuit to feed the new unit. Article 210.23(A)(1) allows cord and plug devices not fastened in place to exceed 80% of the the branch circuit rating. a 1500 W device will draw 12.5 amps which is 1/2 an amp greater then the 12 amps allowed on a 15 a circuit. If the branch circuit is rated for 20 amps you would probably be ok, but if that circuit also feeds another appliance you may have problems. Call an electrical contractor that gives free estimates and get your question answered for a safe installation.
    Nov 2003
    Hey Mr Chesapeake, have you been stealin' stuff from my e-lectrical boxes?
    Jun 2010
    Philadelphia PA
    Are there pennys under the fuses? That also means 1920's wire like knob and tube.
    Sounds like a major problem. Have an electrician stop and visit you ASAP
