Results 1 to 10 of 10
Thread: Green cylinder
    Sep 2009
    Green cylinder
    Hi, does any pro here know the accurate weight of an EMPTY 30-lb R22 green cylinder? Need to figure out how much R22 is left in it. Thanks!
    Fort Worth, TX
    Find a completely empty R22 cylinder and weigh it. Then you'll know with certainty.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Sep 2009
    I know that, the problem is no empty ones are available.
    Quote Originally Posted by shophound View Post
    Fort Worth, TX
    How much does the one you now have weigh?
    Sep 2009
    current total weight is 20 lb 5 oz. thanks!
    Jul 2009
    Plant City, Florida
    weigh a full cylinder of the exact same brand and then deduct 30lbs, that will give you the weight of an empty cylinder.
    Sep 2009
    I know that too, the problem is that NO full cylinder of that brand is available either. I only need the estimate weight of the remaining R22, most green cylinders are of similar weight. thanks
    Sep 2009
    S.C.
    Roughly 6lbs. I think my last one weighed 6 3.
    Yes, I know I Shouldn't But I Just Can't Help Myself...
    Langley, BC, Canada
    most bottles should have a weight stamped on them, thats the empty weight of the cylinder, do the math
    Sep 2009
    Thanks.
    Quote Originally Posted by Home&Marine View Post
