Results 1 to 13 of 14
Thread: Where to buy saddle clamps?
05-31-2010, 01:57 PM #1
Professional Member*
- Mar 2006
- DFW
- 3,967
Where can I buy some 6" PVC saddle clamps like the ones used here? http://www.rackattack.com/product-pa...kit-6-inch.asp I tried HD and Lowes and they dont have them. The plumbing supply house by me said I need a license to buy from them. Who sells just the saddle clamps?
05-31-2010, 02:10 PM #2
I just bend a piece of 3/8 allthread and nut and washer them.
05-31-2010, 02:37 PM #3
- Mar 2006
- DFW
- 3,967
05-31-2010, 02:50 PM #4
05-31-2010, 02:58 PM #5
05-31-2010, 03:48 PM #6
- Mar 2006
- DFW
- 3,967
Thanks. I put a bolt in the back section of the pipe through my ladder rack and then put a black rubber straps around the front and back but they are already cracking. I noticed while driving around that the other service trucks that use the PVC tube were using U bolts/threaded rod to keep them in place.
05-31-2010, 04:00 PM #7
Keep a bolt or some type of small protrusion that the PVC tube is tightened against using the U bolts.
The PVC tube may shift in a minor collision otherwise.
Happened to someone I know. The only thing that slowed it down was the endcap. Still dented the truck cab, though.
If you have something solid like a forklift propane cylinder to put a larger radius pre-bend in the all thread, you have a smaller chance of kinking it bending around something smaller initially... but 3/8" usually bends easily.
05-31-2010, 05:24 PM #8
If you want to get fancy use stainless steel all thread washers/ nuts.
It takes courage to grow up and turn out to be who you really are.
- E.E. Cummings
05-31-2010, 06:30 PM #9
- Mar 2006
- DFW
- 3,967
Well I dont keep any pipe in mine. I keep a large fold out umbrella for those really sunny days while changing out a compressor, and 2 spare tanks - an oxy and acet. I dont know how safe the oxy acet tanks are in there. I keep waiting for the umbrella to shoot out the 6" PVC like a bazooka.
05-31-2010, 06:34 PM #10
05-31-2010, 08:43 PM #11
(1) Pretty sure it is illegal (DOT) to carry gas bottles in anything but an upright position.
(2) Acetylene gas is dissolved in acetone in the bottle. There is a porous filler in there, too. Transporting acetylene in anything but a horizontal position is bad. Using the same bottle before it stands upright for 8 hours is bad, too.
I suggest you do some reading up on acetylene so you realize just how dangerous it is.
The umbrella is the least of your worries.
05-31-2010, 09:15 PM #12
Add to that, the oxogen and acetylene are bad enough apart, together they are really a dangerous idea, for gods sake done put an oily rag in there with them.
05-31-2010, 09:17 PM #13
Mmmmmmmm... linseed oil.....
