Results 1 to 13 of 15
Thread: Brass to Copper
07-11-2004, 08:04 PM #1
- Aug 2003
- Charleston,SC
- 515
Guys...need a few suggestions. Got a 20 ton TXV 7/8 in and 1-3/8 in, anyway...the exsisting one was heated, in my opinion not very much and was rather easy to remove. Problem is when trying to install the new one having problems joining the brass to copper. Might even been discussed before, again any help would be welcomed. Don't think I got enough room for a compression fitting. Oops...before you ask the brass 1-3/8 fitting is the back of the distribution header....Later
07-11-2004, 08:17 PM #2
I think you need to use some sand cloth, stay silv. with brazing flux, and safety-silv 40. Its a 40% silver brazing alloy. Peace.
"If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
07-11-2004, 08:22 PM #3
If your using a 15% It won't happen. I would suggest brazing with 40% silver wire and lots o flux. Also I'd use oxy/acetlyne.
Sometimes when I consider what tremendous consequences come from little things, I am tempted to think there are no little things!
07-11-2004, 09:23 PM #4
- Aug 2003
- Charleston,SC
- 515
Thanx guys...will be back on the repair probably Tues/Wed will keep you posted...by the way...it was 7/8 in and 1-3/8 out...my bad...Later
07-11-2004, 10:27 PM #5
You have to use silver solder flux or it won't work.
Quote
Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
"We can't solve problems by using the same kind of thinking we used when we created them."
Albert Einstein
07-12-2004, 08:32 AM #6
- Jun 2003
- 118
According my Harris handbook it should be Stay-Silv 15% and and Stay-Silv white flux. I made the mistake of using 45% on copper lines into bronze valve years ago and it didn't work. I had to take it apart and start over with 15% and flux, then it was fine. Roger
If you don't have the time to do it right the first time, when will you have the time to do it over?
07-13-2004, 02:34 PM #7
- Sep 2003
- Atlanta, GA
- 128
What I learned back in the dark ages was:
Copper to steel or brass use 45% silver with the proper flux.
Sil-Phos and other 15% stuff was for copper to copper, without flux.
I know you can make it work on the other combinations with flux but it was originally for copper to copper.
I have seen some crummy brazing jobs where techs mis-applied alloys.
Now the issue of txv's:
I personally like to use soft solder (Stay-Brite #8 or equivalent) to connect the valve to the distributor. I have never had a problem with this and if the valve ever has to be removed it lessens the chance of burning up the distributor. I have seen techs even melt out distributor tubes while trying to remove a txv.
jmho.
07-13-2004, 05:12 PM #8
had to do 2 inch and one eighth copper to cast last week used silver solder suggest that and agree with other replys
07-13-2004, 06:37 PM #9
New Guest
- Jun 2004
- Virginia
- 52
15% braze is for copper to copper,or copper to brass W/ white brazing flux.You can use 45% with any of it.Its just cheaper to use 15%Soft solder is not suposed to be used on any refrigeration.I know they did it for years,but that dont make it right.
07-13-2004, 07:33 PM #10
- Jun 2004
- 72
Stryder,
I've had really good luck with Stay-Brite #8 Silver bearing solder. The way I do it is get the fittings really clean with sand cloth or wire brush, I then use Stay-Clean liquid soldering flux (red Bottle) and use low heat to draw in Stay-Brite solder. Works great to close gaps to .005" and will hold up to vibration and high pressure and is recommended for refrigerant use.
check it out: http://www.jwharris.com/jwprod/solderalloys/#SBSolder
Good luck!
07-14-2004, 05:36 PM #11
- Feb 2004
- 534
I like Stay-brite I used to braze them in but I found that requires way to much heat Stay-Brite is the way to go. Oh and don't forget clean, clean, clean!!!!
07-14-2004, 08:16 PM #12
I was taught never to use soft solder in a refrigeration system. I now question that wisdom. The pressure rating of Stay-Brite is more that enough to handle the pressures found in most refrigeration systems.
One problem you may be having is that if soft solder was originally used and you didn't clean it all off, your silver solder will be contaminated and you will not get a good weld. You stated that it came off easy and that may be why.
When brazing large fittings you need alot of heat. If the solder is globing and will not flow you need more heat. Use oxy- acetelyne with a tip large enough for the job."The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
"Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
"Beer is living proof that God loves us and wants us to be happy" --Benjamin Franklin
07-15-2004, 12:08 AM #13
I rarely use stay brite on refrigeration, only if I have to. But, that's just the way I do it, I think it's too easy to overfill the joint and get those little slag peices through-out your system or jam up a cap-line.
When I have used it though, it held up just fine.
Just my .02Sometimes when I consider what tremendous consequences come from little things, I am tempted to think there are no little things!
