Results 1 to 7 of 7
    Jan 2002
    New Hampshire
    I've seen thermometer wells in copper that look like a piece of 1/4" tubing brazed through and diagonally across a piece of 1 1/8" tubing, or similar in other sizes.
    The purpose was to stab a thermometer into the center of the gas flow without a hassle with the insulation, or the freon.
    Anyone know where I can find these?
    Noel
    In the classroom...
    Originally posted by Noel Murdough
    I've seen thermometer wells in copper that look like a piece of 1/4" tubing brazed through and diagonally across a piece of 1 1/8" tubing, or similar in other sizes...
    ...Anyone know where I can find these?
    Noel
    Try your local Lennox distributor.
    Prof. Koldenhott
    HVAC Instructor
    "Those that CAN...teach...
    PASSIONATELY!"
    Jan 2002
    New Hampshire
    Noel
    You are not talking about a petes tap are you? If so they are only used on fluids and not used on refrigerants.
    SE Michigan
    You can make one.
    Midwest
    I think you're supposed to put something like mineral oil? in the hole, not just stab your thermometer into it?
    Mar 2002
    Richmond, Virginia
    They were shipped with earlier Lennox units and used for testing. Lennox has abandoned this approach to testing the charge. Not sure if they are still available.
