Results 1 to 13 of 26
    What I like to do is locate my next call BEFORE I start driving there. I make a mental note of the exit I will be taking as well as which direction I will be going once I do exit.
    Another tip is when the call comes in, I ask myself what I used for parts the last time I had a simular call.
    I might want to swing by the parts house and pick me up a motor or some gas or something.
    Another tip is when your at an account and your not familiar with their layout .... get on the horn and find someone in your company who is familiar and you wont spent untold wasted time looking at or working on the wrong piece of equipment.
    Please feel free to make contributions. Thanks.
    SE Michigan
    Make sure your dispatcher is not hung over.
    Now the freaks are on television, the freaks are in the movies. And its no longer the sideshow, its the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and were dealing only with the freaks. - Jonathan Winters
    Apr 2003
    Iowa
    Payoff the cops to turn thier head when you fly by at 90mph
    I have found that multi-tasking helps a lot. I carry my laptop with me through the day so as I am sitting and waiting for a vac down I can do an estimate.
    If I don't have an estimate to do, get all the refrigerant lines done and connected and start the vac pump pumping as you do all the wiring. By the time you are done wiring, vac is done.
    Don't put tools away until you are ready to walk away. If you put your brazing stuff back in the truck and then turn the vac pump on, you'll have a leak, guaranteed .
    When doing planned service on a furnace.... You just have to get a system down. I can usually do a full blown service in 20 minutes if nobody is bugging me. That's just something that comes with experience I guess.
    There are 3 ways to do anything in life; Good, Fast, Slow: You can pick any 2.
    Jan 2002
    tip of the mitt
    A good punch list helps on those jobs that require a second trip. A compete model and serial number with job descripton that is recorded in the customer file helps. We like to print out the last service ticket for the customer with a work order. Calling ahead and confirming arrival times. No sense making a wasted trip, some folks forget or something came up.Digital job pictures showing all particulars, this is especially good for retrofits and changeouts.
    I have my own little world. But it's OK...they know me here.
    Whenever gassing up a rack, from down in the cases, I like to pull out the valve core and hook up a couple of jugs at a time. This makes a hundred pounds go in quickly.
    I carry a H25-597, page 936, catalog # 194. Valve core removal tool.
    Without one of these tools in your arsenal, you are working in the stone age.
    Jul 2002
    Slacking off right now
    like to pick up parts for recomended repairs for a few jobs all at once particulary on the way home so I can get a jump on the job and have some real coffee time eh!
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    oil-2-4-6-gas is offline Professional Member b&M _email server rejected
    1)gas in the truck at the end of the day(2)get direct deposit(3)at the deli -order your food then shop for drinks or call in ahead-(4)any job you go on write down as much info as possible -mod# ser# motor size controls etc.. for next time--(5) When you need parts from the supply house call and check stock(6)if the supply house is busy and a long line go in the parking lot and call in (7)never put your tools away until you are done(8)organize your truck(9) take pictures
    Keep the van or truck clean
    Nothing helps organization better.
    Earth
    Keep an open mind, and always look at the big picture. If you cant figure it out get help. There is a big difference between making it run, and making it right.
    Start at the beginning on every new job. If it's an a/c call check the furnace first and work your way outside.
    Don't talk too much till you are done, even then keep it short and simple. Try not to think about the next job, concentrate on the one you are on first. Don't be afraid to ask for money, if they offer it, take it.
    If all else fail, drop back and punt.
    Hey cockroach, don't bug me!
    Jul 2000
    Cuenca EC
    Keep your truck well stocked with all the parts and materials you regularly need for the type of work you do.
    Nothing can screw up a simple job more than having to drop everthing and run to the supply house for something you should have had all along.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    The Alamo
    For new installations we have a check list that includes all of the tools and parts we need, permits, financing info, rebate forms and warranty application. I try to do all of the financing and warranty paperwork once the equipment is picked up so I don't have as much to do at the end of the day.
    NJ
    I try to be an efficeincy expert I give a flat rate so anytime I can figure out away to knock a few minutes off the work time I do it whether it be buying a more efficient tool or like sarge i actually have certain tool/material setups one geared towards install and the other to service. And I have the paperwork prepared in my own home. On blower motor changeouts where i dont have the motor aand need to go to the supply house I bring the whole thing with me and pull it at the supply house and reassemble it there so when I get back I only have to slap it in and hookup the wires... the less customer contact the better I have suffered from my foot in my mouth disease too many times.
    [Edited by thehumid1 on 07-08-2004 at 03:32 PM]
    thehumid1-------I live in NJ, a state where it's free to come in but you have to pay to leave!
