Results 21 to 28 of 28
Thread: Interpreting Manual J Results: 2-ton or 2.5 ton?
  1. #21
    Houston,Texas
    Manual J cannot compensate for bad or old insulation in walls.
    Quote Originally Posted by beshvac View Post
    there is nothing that causes it to lose its insulating value. Show me anything that proves insulation loses any of its rating over time.........
    Again, more words read into what I said, I never said “there was anything that causes it to lose its insulating value” some folks just need to take a deep breath, and read all the posts here on the forum a little more carefully.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
  2. #22
    Apr 2009
    R.O.T.
    Quote Originally Posted by pstu View Post
    Has ACCA Manual S become unnecessary? I am a homeowner and not qualified to tell another what the answer is. But I have purchased the Manual S book and read the way the AC is supposed to be de-rated for the design day conditions, and then selected so that it matches both latent and sensible loads separately. In other words I have always been told that if your house has 24,000 BTUH combined sensible and latent loads, you usually don't want your AC to have 24,000 capacity rating.
    Hope this helps -- Pstu
    Yep, yer right, sensible and latent need to be looked at separately. Then find a unit in the brand you want that fits the bill. This is how alot of companys get into trouble with sizing cooling loads.
  3. #23
    Manual J is accurate if the input is accurate,insulation in walls doesn't "get old" in a way that changes the R value.
    No extra "input" or "guessing" is needed or wise.
  4. #24
    May 2010
    Manual J & S
    The reason for the increase use of these manuals is to qualify for the rebates that are offered in some states. I am in NJ and to get the rebate from the state run program they want to see a Man J and S calc within 15% variance. I am a builder and do most of my own HVAC work that only applies to A/C. I use boilers for heat. Not many hvac contractors (in my area)know how to do these calculations, they sub it out to an engineer. They size the units from experience. Sometime they hit it dead on other times.... well oversizing = musty problems. I may consider purchasing the manuals from ACCA.ORG.
  5. #25
    Quote Originally Posted by Robelander View Post
    Every contractor in the country should have and use ACCA manuals.
  6. #26
    Jan 2002
    East Grand Forks, MN
    Quote Originally Posted by dash View Post
    As long as there isn't a must in there!
    Let the local regulatory enforcement offices handle that!!!
  7. #27
    Quote Originally Posted by arc8 View Post
    The local regulator broads couldn't make a better choice,what did they choose in your area,nothing at all???
  8. #28
    Jan 2002
    To each his own city!
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
